High stall converter with stock cam profile?? #994919
05/18/11 01:57 PM
05/18/11 01:57 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
What will a high stall (2300-2700) converter do with a basically stock 318 roller cam motor? (stock roller cam, Edelbrock performer RPM, swirl port heads with intake ports matched. and a 600 holley.)
Go Fast and Swerve!
Re: High stall converter with stock cam profile?? [Re: way2fast] #994920
05/18/11 02:04 PM
05/18/11 02:04 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
the converter I'm considering is a 145K recommended for valve lift up to 0.450" would this work if i want to do occasional towing
Go Fast and Swerve!
Re: High stall converter with stock cam profile?? [Re: way2fast] #994921
05/18/11 02:09 PM
05/18/11 02:09 PM
scratchnfotraction Offline
I run a stock HS-LU in my a999/904 tranz with the voodoo roller cam
same stock HS-LU unit that was on the stock roller engine combo
works good in my daily driver,lets the 318 move out of it own way compaird to the LS-LU I had in the other 904 tranz
but i think its more like 1800-2200
you looking at aftermarket TC?
seems a little high for a stock 318 roller cam profile,more toward a 360 engine
Re: High stall converter with stock cam profile?? [Re: scratchnfotraction] #994922
05/18/11 02:15 PM
05/18/11 02:15 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
It doesn't specify the stall speed just has "145K High stall" on it. I just assumed 2300 +.
Go Fast and Swerve!
Re: High stall converter with stock cam profile?? [Re: way2fast] #994923
05/18/11 02:21 PM
05/18/11 02:21 PM
think that what mine rated at
I get a new reman TC from the local tranz shop for 120$
I use the stock HS unit for a mid 80s 318 car
i throw a new one in with every used tranny swap I do,most of mine come with low stall TC in the trucks at the pick n pull
with a under powerd smog 318 its night and day on the "pep" it give it
Re: High stall converter with stock cam profile?? [Re: scratchnfotraction] #994924
05/18/11 02:27 PM
05/18/11 02:27 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Ah ha! just found the stall speed...1900-2100
https://board.moparts.org/ubbthreads/upload2/6413365-P4529403AB_table.jpg
so looks like this should work out.
Go Fast and Swerve!
Re: High stall converter with stock cam profile?? [Re: way2fast] #994925
05/18/11 02:35 PM
05/18/11 02:35 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The older factory service manuals list the stall speeds of many engine/trans combinations. The stall speed you state doesn't sould too far off the mark for a stock application.
