Spark plugs #994908
05/18/11 01:41 PM
05/18/11 01:41 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..the old stand by for an early 340 was N9Y.
..so how does RN9Y differ and what effect do these resistor (?) plugs have on an engines' performance?
Re: Spark plugs [Re: can.al] #994909
05/18/11 02:21 PM
05/18/11 02:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It has a resistor , you should be happy you can even get the correct heat range plug assuming the engine is stock .
