Re: Neutral safety problem or ......
[Re: Jim_Lusk]
#994453
05/18/11 10:51 AM
05/18/11 10:51 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If it does not reliably start in neutral. I'd start by replacing the switch.
If I read that wrong and it's only a problem in park AND all the gears work correcting relating to the shift indicator. It may be worn linkage. After years of use some of the pins wear, become smaller. Also the holes wear and become oval. So the linkage can not push the transmission fully into park. You adjust to compensate, then you can not go into 1st.
Bypassing is bad advice.
[Re: AverageJoe]
#994455
05/18/11 02:17 PM
05/18/11 02:17 PM
Posts: 25,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The problem is a linkage issue which might be need for adjustment or slop caused by worn/missing plastic bushings in the linkage.
Crawl under the car and have someone run it through the gears, look for slop in the linkage.
