Intermediate Shaft Orientation (Oil Pump Drive) #994303
05/17/11 05:40 PM
05/17/11 05:40 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
Putting the drive back in at TDC shows the angles to be just below or just above the level. Can't put it level.
Assuming I'll live with this, which to live with; just above that line or just below?
Re: Intermediate Shaft Orientation (Oil Pump Drive) [Re: GwaiiEagle] #994304
05/17/11 08:01 PM
05/17/11 08:01 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
It doesn't really matter. Just put the distributor in and make sure it's TDC (or even better about 10 degrees before)on the compression stroke. Make sure you can turn the distributor both ways. (So you can advance or retard the timing.) Whichever terminal on the distributor cap the rotor button is pointing to plug the #1 plug wire into it. Then do the rest of the plug wires in firing order in the direction the distributor turns.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: Intermediate Shaft Orientation (Oil Pump Drive) [Re: johnedod] #994305
05/17/11 09:41 PM
05/17/11 09:41 PM
set the crank/timing cover timing marks on the initial amt (ie 10BTDC) you plan to run (#1 compression of course) then index the inter gear (wherever) so it locates the rotor under (or very near under) the #1 dist cap terminal w the dist housing located in factory position where the vac can has room to b turned and if you are locating your plug wires from scratch the factory diagram is best for standardization for future reference and it lets the wires nestle neatly w the shortest route and diff dizzys can have diff top rotor slot to bottom shaft tang orientation and the bottom line is you want the rotor blade as close to dead center on the underside cap terminal as possible when it fires and only vac adv will alter rotor phasing from that point (moves it CW on a BB and CCW on a SB) EDIT forgot, turn dist till the magnet slot is dead even w the nearest reluctor tooth then move the housing (magnet) a hair more past the tooth opposite dist rotation w the rotor under #1
Re: Intermediate Shaft Orientation (Oil Pump Drive) [Re: RapidRobert] #994306
05/17/11 09:58 PM
05/17/11 09:58 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
If you have #1 on TDC the slot in the oil pump drive will line up in straight line to the #1 cylinder location. FWIW this should give you plenty of adjustment fore and aft. The other methods will work as well, but make sure you pick a consistent method and stick with it.
Re: Intermediate Shaft Orientation (Oil Pump Drive) [Re: wheelsup68dart] #994307
05/18/11 12:54 AM
05/18/11 12:54 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Again, the FSM states the slot in gear should be parallel with crankshaft when installed properly at TDC compression stroke, looks like your's is as close as it will get.
