High Rise throttle cable and kickdown ?? What 2 use #993790
05/16/11 08:08 PM
05/16/11 08:08 PM
DELAWARE
bee71mopar Offline OP
DELAWARE
Ok can someone post pictures of there high rise intake,right now I have a Weiand single plane and a 780 Holley.I am getting ready to buy a E-RPM manifold.I need the setup for the Weiand single plane first.Can anyone HELP!!!!
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: bee71mopar] #993791
05/16/11 10:12 PM
05/16/11 10:12 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Contact AndyF of AR engineering. He has brackets and other trinkets that will help.
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: bee71mopar] #993792
05/16/11 10:19 PM
05/16/11 10:19 PM
AndyF Offline
AndyF  Offline
Hughes Engines or Mancini Racing have what you need.
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: bee71mopar] #993793
05/16/11 10:21 PM
05/16/11 10:21 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have the Lokar cables on Gina's 72 charger.
Cut to enough length you can do any intake/spacer combination.
This happens to be a 360 W/ a RPM air gap and 2" spacer.
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: bee71mopar] #993794
05/16/11 10:31 PM
05/16/11 10:31 PM
AndyF Offline
AndyF  Offline
Here is the standard hi-rise throttle bracket from Mancini or Hughes.
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: AndyF] #993795
05/16/11 10:32 PM
05/16/11 10:32 PM
AndyF Offline
AndyF  Offline
Here is the style for the three part KD linkage.
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: bee71mopar] #993796
05/16/11 10:35 PM
05/16/11 10:35 PM
DELAWARE
DELAWARE
Thanks !!!!
Re: High Rise throttle cable and kickdown ?? What 2 use [Re: AndyF] #993797
05/17/11 08:38 AM
05/17/11 08:38 AM
Ft. Lauderdale, FL
solarguy Offline
solarguy  Offline
Ft. Lauderdale, FL
is there a small block version of that?
