73 Roadrunner big block oil pan #993781
05/16/11 07:43 PM
05/16/11 07:43 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I have a 73 Roadrunner factory small block car that I'm putting a 440 in with schumacker mounts and the factory small block K-frame. Does anybody have a picture of the oil pan that will work for this project ? I have a couple oil pans but I don't see any numbers on them.
Re: 73 Roadrunner big block oil pan [Re: 73rrak] #993782
05/16/11 09:21 PM
05/16/11 09:21 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's the thread in the tech archives/best of... link
Re: 73 Roadrunner big block oil pan [Re: screamindriver] #993783
05/16/11 10:55 PM
05/16/11 10:55 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I think (somebody chime in) that the chinese deep sump pans will fit the 73 k frames.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 73 Roadrunner big block oil pan [Re: Von] #993784
05/17/11 12:19 AM
05/17/11 12:19 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
One of the pans I have is almost the same as the 971 pan in the link but it has clearance for steering linkage on the back side of the sump but the sump looks like it's in the same location. The only markings it has is SS41-1 stamped in very small letters on the bottom of the pan. Will this pan work ?
