Check out my plugs................ #993017
05/15/11 04:45 PM
05/15/11 04:45 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
These are in order facing the engine. They have about 500 miles on them since new. So what can you tell me as some look fine and some are pretty gunked up. I run only Chevron 91 octane super by the way.
I am going to clean them up and reuse.
Re: Check out my plugs................ [Re: MidPenMopar] #993018
05/15/11 05:10 PM
05/15/11 05:10 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
looks like your sucking some oil from the intake runners.
Re: Check out my plugs................ [Re: ireland383] #993019
05/15/11 05:14 PM
05/15/11 05:14 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Check out these pics to compare. Looks like oil fouling and some heavy deposits on several.
http://www.google.com/imgres?imgurl=http...ved=0CBcQ9QEwAg
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Check out my plugs................ [Re: MY340] #993020
05/15/11 05:21 PM
05/15/11 05:21 PM
Hummnnn??? Looks like the back cylinders are not so happy.
Re: Check out my plugs................ [Re: ireland383] #993021
05/15/11 05:59 PM
05/15/11 05:59 PM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
Or valve guides/seals.......
Karma has no menu. You get served what you deserve.
Re: Check out my plugs................ [Re: SKR8PN] #993022
05/15/11 06:04 PM
05/15/11 06:04 PM
I noticed i am getting some slight engine oil puddling in the valley of the intake as well.
Re: Check out my plugs................ [Re: MidPenMopar] #993023
05/15/11 06:08 PM
05/15/11 06:08 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
You must be using some oil?
Re: Check out my plugs................ [Re: ireland383] #993024
05/15/11 06:08 PM
05/15/11 06:08 PM
NY NY
3
340duster340 Offline
NY NY
agree definitely burning oil...those crusties sound fun if they come off and bounce around inside the cylinder.
my truck burns massive amounts of oil, every now and again a piece of the burn build of comes off and the motor tics like a banshee, eventually the noise goes away, and i just change/clean the plugs ever few thousand miles.
Re: Check out my plugs................ [Re: MidPenMopar] #993025
05/15/11 06:09 PM
05/15/11 06:09 PM
Indiana
maxie Offline
maxie  Offline
Indiana
I had a vacuum leak that took for ever to find. It turned out that the inatke gasket hadnt sealed and the leak was between the gasket and the head, sucking air/oil from inside the motor.
Re: Check out my plugs................ [Re: MidPenMopar] #993026
05/15/11 06:10 PM
05/15/11 06:10 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Valley pan gasket/runners leaking. Needs to be redone.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Check out my plugs................ [Re: amxautox] #993027
05/15/11 06:35 PM
05/15/11 06:35 PM
New Jersey
myrddin Online content
myrddin  Online Content
New Jersey
You need these:
gasket set
Re: Check out my plugs................ [Re: myrddin] #993028
05/15/11 06:58 PM
05/15/11 06:58 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Stu, make sure you sealed the threads of the intake bolts with some RTV. Oil can seep up through the threads. And yes it does look like a little oil burning.
Re: Check out my plugs................ [Re: myrddin] #993029
05/15/11 07:00 PM
05/15/11 07:00 PM
You need these:
gasket set
Yess i do some oil like maybe a pint every 500 mies or so. Well then next on the list i will go for the valley pan gasket set i guess as that's pretty easy to do.
Re: Check out my plugs................ [Re: MidPenMopar] #993030
05/15/11 07:21 PM
05/15/11 07:21 PM
New Jersey
New Jersey
Sorry, just realized that set is for B engines, this is the RB set:
RB set
Re: Check out my plugs................ [Re: bigblock340power] #993031
05/16/11 12:30 AM
05/16/11 12:30 AM
That intake nas been untouched for 10 years so maybe it's time for some new gaskets??
