Re: Torsion Bar help..Install
[Re: bigblock340power]
#992214
05/14/11 03:17 PM
05/14/11 03:17 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I put the boots on outside the car & slide them in from the front... BTW throw the boots in some boiling water grab them out with tongs, wear gloves & use lube... They really are a PITA to stretch over the hex...
[Re: moparrulzzz]
#992216
05/14/11 04:22 PM
05/14/11 04:22 PM
RapidRobert
Yeah if you have enough susp removed up front 2 where you can get em in from the front as it lessens the chance of a nick from inserting the whole length from the rear (though rare but why take chances if you dont have to) & as mentioned it lets u slide the boot on the rear end of the tbar outside the car which is always easier
