Need measurements for locating Headlight Dimmer Switch #992104
05/14/11 09:30 AM
05/14/11 09:30 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Wuz ready to install Carpet,'til I realized i didn't have dimmer switch installed! Can Somebody please give Me measurements in a '67 B-body on where to locate?? Eric @ Rickety Enterprises..
Re: Need measurements for locating Headlight Dimmer Switch [Re: gassy66] #992105
05/14/11 10:50 PM
05/14/11 10:50 PM
Missouri
convertriple Offline
super gas
super gas
Missouri
On my 73 A-body, I went to the wheelwell and found the holes for mounting it, then pushed a scribe-like tool up through the carpet from the wheelside of the firewall. Once you have both holes located, you can see where to cut.
