brake question - Update ---More help
#99204
08/03/08 07:53 PM
08/03/08 07:53 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Should fluid shoot up from the front resivouir of a master cylinder when the cover is off???
This woudl be on my 74 cuda with power brakes
Re: brake question
[Re: sthemi]
#99206
08/03/08 08:23 PM
08/03/08 08:23 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Your brake system needs to be completely sealed to work properly. If its not you need to repair any and ALL leaks of brake fluid
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: brake question
[Re: sthemi]
#99207
08/03/08 08:57 PM
08/03/08 08:57 PM
CUDAJAS
If the cover is NOT OFF, there should be no fluid visable.It s a sealed unit. Nothing in or out. With the cover off it is normal to see a stream of fluid shooting up when the pedal is pressed.
Nope no leaks with the cap on.
but, this is a new reman master, bench blead master, most new parts, blead brakes twice, and get no air. Brakes are real soft, peedle goes right to the floor with car running.
Re: brake question
[Re: CUDAJAS]
#99210
08/09/08 01:22 PM
08/09/08 01:22 PM
RapidRobert
I would start over & bleed MC then RR LR RF LF.be carefull with bleeder screws so you don't let air get pulled back in. DAMHIK
