440 Rough Running-A bit at least #991239
05/12/11 10:31 PM
05/12/11 10:31 PM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
I have been driving my 440 Dart Sport for 10 miles at a stretch or so. Engine is used but no smoke or low op with new gaskets and a .450-.455 cam, SD intake, and an Eddy 600 (just a carb to get the car going carb-runs perfect on my other rigs).
The car has a bit of a rough running condition out on the road at cruise. Kind of a light bucking or backfire here or there at speed. If you rev it at idle it doesn't clear out quite as smoothly either as it should. Just kind of hick ups and pops mildly here and there but will pull RPM.
Timing is this: It has about 36 degrees at 2300 RPM with the vacuum advance plugged. I set this with a dial back light. I had to go over 20 degrees initial to get that though. It starts ok and pulls 17 +/- inches at 800 RPM idle. Runs good down low.
The wires and new, plugs are new, I switched cap and rotor etc. with another set off of the shelf.
The car acts the same at cruise no matter where the timing is set at within reason. The car is driveable as is, but it drives me nuts with the mild issue.....
Is there a chance that the control box, coil etc. could be part of this?
The ballast resister is stock 1974. The control box is stock. The car sat for 20 years so who knows what is what there.
The coil is an Accel Yellow coil that is round, I believe it was from a points application, not sure that it matters.
Thoughts or ideas? I should say that I drove it very briefly last summer and it was the same.
Carb? Ignition?
Thank you, ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991240
05/12/11 10:46 PM
05/12/11 10:46 PM
N.E. Ohio
6bblFLASH Online content
6bblFLASH  Online Content
N.E. Ohio
Re-check the plug wires/firing order. I`ve done that more than once
Also kinda sounds like a fouled or cracked plug.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991241
05/12/11 10:50 PM
05/12/11 10:50 PM
It has about 36 degrees at 2300 RPM with the vacuum advance plugged. I had to go over 20 degrees initial to get that though.
Thoughts or ideas?
The dist slots are only giving you 7.5 in the dist 36-21=15 divided by 2=7.5??. Real quick might plug in the vac adv & see if it gets better/worse/same
Re: 440 Rough Running-A bit at least [Re: RapidRobert] #991242
05/13/11 12:29 AM
05/13/11 12:29 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
son had same thing on warmed over 360 in truck and we fianlly found out that w/stock ign box aftermarket coil is a no-no-try stock coil and see if it help-also better carry an extra box just in case
Re: 440 Rough Running-A bit at least [Re: rbkt65] #991243
05/13/11 01:48 AM
05/13/11 01:48 AM
Southern Oregon
Southern Oregon
I was thinking about this for awhile tonight. For all of its faults, the car has always had a similar issue to this, or it has never left. The very first day I drove it it felt the same.
That was another engine etc. What ever it is has been wrong with the car from day one when I first started the car.
I have noted your statement regarding the coil. I have a fair pile of spare ECU's and coils etc. and I will try and replace one tomorrow.
And Robert, I am sure there is some distributor work to do. It have a few parts ones etc. to mess with along with different degree advance plates etc.
Whatever is causing this, it is does not appear to be fuel related since I have had three different carbs, and two engines.
Keep in mind, this is a project car that does not get driven. I think I have 20 miles max on the car. I am finally closing the deal and getting it done.
ROB
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991244
05/13/11 11:29 AM
05/13/11 11:29 AM
Southern Oregon
Southern Oregon
I pulled the coil off. It is the Mopar one that Accel makes for Mopars and ends in M, or at least the PN says so.
So far here is what I have done, all with parts on hand.
1. Different coil wire
2. Different coil
3. Different coil polarity
4. Different ignition control box
No differece, car runs the same. I am going to go through the firing order again, and then start checking wires with my DVOM.
It is a bit like a bad plug wire..
More later.
ROB
I'm thinking I wil
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991245
05/13/11 11:58 AM
05/13/11 11:58 AM
michigan woods
imfixinmopars426 Offline
michigan woods
first...check the compression on all cyl's..i hate to say,but sounds like a valve leak.
Re: 440 Rough Running-A bit at least [Re: imfixinmopars426] #991246
05/13/11 12:56 PM
05/13/11 12:56 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I have been chasing the same problem on my stroked 440 for 3 summers.
i have finnaly determined the the the problem was the carb .
it was to lean in the transisiton circuit of the carb .
This is where you run most of the time when crusing, changing main jets only masked the problem and makes the engine run to rich.
For you you may want to look into a couple of theads , Tunning with an o2sensor . and Demon carb ?'s . There is good info about tunning the idle feed restrictions to get the car to cruse at the proper a/f ratio required by the engine . every motor needs its own a/f number keep that in mind . hope this helps you . CJ
1969 Dodge Charger 1969 Dodge Superbee
Re: 440 Rough Running-A bit at least [Re: cjs69mope] #991247
05/13/11 02:43 PM
05/13/11 02:43 PM
Southern Oregon
Southern Oregon
Ok. Also, I discovered that the advance plate (or whatever the proper term is) is "mushy feeling" for lack of a better word, it is loose.
I am looking into that here in about an hour.
ROB
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991248
05/13/11 11:14 PM
05/13/11 11:14 PM
Southern Oregon
Southern Oregon
OK. I fiddled with it some more and test drove it again.
The "rough" running is definitely RPM related. It somewhat bucks and so forth at certain speeds. I don't have a tach in the car right now, but it is in second at about 25 MPH or about 55 MPH in 3rd.
Currently my total timing is 36 degrees advance, with the VA plugged and at about 2500 RPM as measured with an underhood tach.
I have done the following, more as learning thing than anything, today:
Different ECU
Different coil
Checked plug wires - all within spec
Checked firing order 3 x's
New cap and rotor
Different pick-up in distributor
Etc. I think you get the point.
Same thing. I can advance / retard timing. It runs a bit different, but it still has the same basic running situation as before.
I am looking closely at the carb. I haven't touched it. It runs so well at idle you over look things. I have never ran it at all on the road, only on this car. The rest of the time it is a low RPM plow truck carb.
At WOT it is smooth and pulls pretty good, but at any constant RPM in the normal driving range it isn't happy.
As some have said, it may be a lean thing. It is an Eddy 600 on a 440 and I live at 4500 ' elevation. Sounds like there could be some lean going on.
Without starting the usual carb fight, I do have a 3310 that I have ran on other rigs. I may throw that on. Not much more to do electrically right now.
One member mentioned doing a compression check. I need to do that as well next week.
Thoughts on the situation being more fuel related? I have a new tank and new fuel pump etc.
Thank you for your help. I will get it going.....
ROB
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991249
05/14/11 12:03 AM
05/14/11 12:03 AM
At WOT it is smooth and pulls pretty good. it may be a lean thing. It is an Eddy 600 on a 440 and I live at 4500 ' elevation. Sounds like there could be some lean going on.
Block the metering rod pistons up & (re)try it
Re: 440 Rough Running-A bit at least [Re: RapidRobert] #991250
05/14/11 12:35 AM
05/14/11 12:35 AM
Southern Oregon
Southern Oregon
I just came across a calibration kit for a 1406 on my shelf. If I could, I would like to keep the carb that is on it and put some miles on the car first before I start up grading it etc. If I give up a few HP so be it for now.
I will have to read up on this carb this weekend since I haven't had to tune this type of carb before.
So, you think I may be experiencing a lean surge type condition?
ROB
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991251
05/14/11 12:43 AM
05/14/11 12:43 AM
I have a 1406 on a 318 & it's lean on the main metering and the choke comes off WAY too fast and the choke pulloff (internal piston) is not functioning. Ain't dug into it yet (waiting for Santa to give me a LM-1) ex for richening up the rods/jets & when it's warmed up past the choke stage it's OK. Yeah I'd block them up for a 15 min test or toss in rods w the thinnest "cruise" step
Re: 440 Rough Running-A bit at least [Re: RapidRobert] #991252
05/14/11 09:28 AM
05/14/11 09:28 AM
Southern Oregon
Southern Oregon
I read the Edelbrock manual that came with my parts. I have three sets of most everything so I should be good.
Set the float height
Install different rods / jets or some combo
Repeat until I get what I want
I can see that a AF guage would be handy.
It looks pretty straight forward. I want to put some miles on the car, and then go chasing performance. There are enough other things to work out first though.
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991253
05/14/11 09:34 AM
05/14/11 09:34 AM
Install different rods. I want to put some miles on the car,
On a level surface start car for 10 seconds then pull rods & carb top & fuel level should b at the notch on the float baffles on each side (iirc the dry setting is 7/16"), reinstall top & perfect time to use the richest "cruise" rods in the kit which ain't even close to being too rich & you'll b up and running in minutes
Re: 440 Rough Running-A bit at least [Re: RapidRobert] #991254
05/14/11 09:48 AM
05/14/11 09:48 AM
Southern Oregon
Southern Oregon
I will post up on Monday with my findings. The car is at work right now which is 20 miles away.
My students and I did learn the inside of the distributor pretty well, and I think any advance work shouldn't be too hard now due to the quality time spent inside of there.
I will confess that as a 4x4 guy if it runs decent it is ok and you leave it alone. Approaching this as a performance car is totally different. OK isn't enough.
They give you a matrix with different percentages to change the settings. Should I go clear to the Rich settings and then see what that does?
I would say that I am feeding close to 100 more cubes than the carb is designed for so I think it would work.
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991255
05/14/11 10:07 AM
05/14/11 10:07 AM
yes, check the float level & right now dont even bother w the charts/formulas, just toss in the richest rods in the box, the "cruise" step which is not the end tip but the next "step" up from there & from my exp w the 1406 you'll have a smile on your face. This'll give you some driveability & let you get some happier miles then later you can work on the dist as sumpin dont sound kosher w it & it needs to be dialed in b 4 the carb then come back to the carb but for now I'd simply richen the carb. Might even put in at least .095" (or bigger) jets in & need just the right width screwdriver shank so you dont scrape the sides going to the jets plus the right length and width blade & push down fairly hard straight down on the jets to break em loose & not gouge them as mine at least were in there solid then put the new ones in MODERATELY snug but not tight. Not being patronizing, just wanting to share my exp w my 1406 EDIT meant .098" or bigger
Re: 440 Rough Running-A bit at least [Re: RapidRobert] #991256
05/14/11 10:35 AM
05/14/11 10:35 AM
Southern Oregon
Southern Oregon
Not worried about patronizing. I do gear work, rebuilt my own 727, paint cars, do body swaps (4x4 thing) etc.
What I have never done is really get a car dialed in. I am finding now that I have officially crested 40 years old that I don't want to drive something that does not run well. I won't drive it / ride it / use it unless I have to.
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991257
05/14/11 11:01 AM
05/14/11 11:01 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Check the distributor for bushing wear. if it is wobbling back and forth sometimes the problem.
says .006 replace think that is from center so .012 back and forth total it is toast. I've seen them with .050 total and yes they ran like crap!
Re: 440 Rough Running-A bit at least [Re: toyotajeep] #991258
05/14/11 11:07 AM
05/14/11 11:07 AM
michigan woods
michigan woods
i ran a 1405 on a 440/.484 cam challenger w/air+3.91.street car,drove all the time and went on trips too.car ran 13.65's all day,and im a freak about drivability. i jetted/needled+spring kitted the carb,and it was great! decent fuel mileage,great low rpm-5500 power also. your carb will work fine if jetted,and if any issues are repaired...so ck the comp yet? yep it sounds like lean cond? my supercoupe was doing that crap,at cruise,and i jetted the 1406 around to take care of most of it,but she has 128k,and is tired. so keep us posted,good luck,mike
