Re: Small block questions....
[Re: MR_P_BODY]
#991073
05/12/11 10:15 PM
05/12/11 10:15 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
A NHRA S/S engine would probably be the closest thing..but I'm only asking for a 10.70-10.80 time slip!! As I mentioned,I threw out the 7200 rpm limit as a suggestion,I don't buzz my B/RB engines that high.If it needs to go 8K,so be it.
On the other hand,if this isn't even feasable,that's fine too.
[Re: Chris2581]
#991076
05/13/11 10:07 AM
05/13/11 10:07 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
"3.31 stroke.. only needs to run 10.50's (10.7's) in a 3400lb A-body." From everything I have read, you want a 3.31 stroke to make about 600 hp and limited to stock type heads correct? You didn't mention if they have to be correct for the year car though. That makes a huge difference as mentioned above.
[Re: TheOtherDodge]
#991078
05/13/11 06:17 PM
05/13/11 06:17 PM
Chris2581
Jacksonville, FL
No the heads don't have to be correct for the year car,have to be iron,and Mopar heads.That's why I mentioned the Mag R/T's.
