66-67 B-body Weight with Aluminum head small block? #991009
05/12/11 04:22 PM
05/12/11 04:22 PM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
Anyone have experience with what a 66-67 B-body could or should weigh with Aluminum head small block/727 combo?
Stroker shortblock, 360 block based
Edelbrock heads/intake
727 trans,
Manual Steering
Aluminum radiator,
Caltracs/Monoleafs
8-3/4 rear
2x3 .120 Frame connectors.
Aluminum wheels
Manual Brakes
AndyF style Wilwood calipers w/ 11.75" discs
Stock interior w/ Bench seats, carpet.
No Rollbar,
No Undercoating,
No AC,
No Heater,
(I have posted this in the question/answer section also)
Re: 66-67 B-body Weight with Aluminum head small block? [Re: topbrent] #991010
05/14/11 06:30 PM
05/14/11 06:30 PM
houston texas
gremlinsteve Offline
houston texas
id just take her down and have it scaled. best way to know what "your" car weighs.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 66-67 B-body Weight with Aluminum head small block? [Re: gremlinsteve] #991011
05/14/11 06:59 PM
05/14/11 06:59 PM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
GremlinSteve
steve
I agree, but I am asking about this as a theoretical exercise.
- Not an actual build at this point.
Re: 66-67 B-body Weight with Aluminum head small block? [Re: topbrent] #991012
05/14/11 07:15 PM
05/14/11 07:15 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
3500. Least that what mine weighs. You be a little less; I have iron heads and power steering.
Re: 66-67 B-body Weight with Aluminum head small block? [Re: topbrent] #991013
05/14/11 07:17 PM
05/14/11 07:17 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I would say around 3,000 lbs if you have everything out. The bumpers are heavy on 66-67 B-body cars,I took mine off and used some.040 aluminum to cover where the bumpers went.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
