Female to male coil wire adapter, where to find? #99057
08/03/08 04:01 PM
08/03/08 04:01 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
Looking for a couple of the adapters that plug into the coil wire connector on a standard coil that change it to a male end, like a spark plug. Does anyone know where to order them from?
Re: Female to male coil wire adapter, where to find? [Re: mkvien] #99058
08/03/08 04:32 PM
08/03/08 04:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not just put a different end on the coil wire?
Re: Female to male coil wire adapter, where to find? [Re: stumpy] #99059
08/03/08 06:17 PM
08/03/08 06:17 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Female to male coil wire adapter, where to find? [Re: Pyper70] #99060
08/03/08 09:22 PM
08/03/08 09:22 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
Yea, that little gadget there. Can't really tell from the description if that comes with the coil wire or not, but I don't want the coil wire anyway. I should dig a little and see if MSD sells that separately.
Re: Female to male coil wire adapter, where to find? [Re: mkvien] #99061
08/04/08 07:34 AM
08/04/08 07:34 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I dont think they do, when I was in Summit Last year in Georgia I told the dude I wanted just the plug terminal for a blaster II coil. He told me that MSD sells only the plug terminal and cable OR I can buy the Blaster 3 coil which it comes standard on.
Best of luck, doesn't hurt to dig but you can always keep a spare coil wire in your trunk and give another to a buddy as a present.
