New driveshaft install #987918
05/08/11 01:50 AM
05/08/11 01:50 AM
Mount Airy, Maryland
scrag Offline OP
scrag  Offline OP
I am putting the final touches to my TKO install in a 70 Cuda - just got the drivesahft and wanted to ask this before I dorked it up. Normally I put a lite coating of grease on the part of the shaft that fits into the transmission - but being a tremec that uses ATF I was not certain - so I thought I would ask.
Re: New driveshaft install [Re: scrag] #987919
05/08/11 05:48 AM
05/08/11 05:48 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
some His & Hers KY Jelly might help...
I am truckless..
Re: New driveshaft install [Re: 340SHORTY] #987920
05/08/11 08:27 AM
05/08/11 08:27 AM
md
W
wicked Offline
wicked  Offline
W
md
Re: New driveshaft install [Re: scrag] #987921
05/08/11 09:57 AM
05/08/11 09:57 AM
If you have a jar of vaseline in your medicine cabinet that would b the best as it melts into ATF and does not chemically react w it.
