Vibration Problem #987623
05/07/11 03:11 PM
05/07/11 03:11 PM
South San Francisco, Ca
70sixpkrt Offline OP
When taking the off ramp of a freeway at 55 mph and pushing the clutch pedal to the floor and foot off the gas pedal I can feel a vibration from under the floor board. Does that sound like u joints, driveshaft? I did replace my clutch last year and did not balance the pressure plate and flywheel together. I was told I did not have to since the pressure plate was neutral balance. I did resurface the flywheel.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Vibration Question [Re: 70sixpkrt] #987624
05/07/11 05:04 PM
05/07/11 05:04 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I chased a vibration like that for a year, turned out the tyres were not balanced correctly.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Vibration Question [Re: Mick70RR] #987625
05/07/11 05:58 PM
05/07/11 05:58 PM
It did not vibrate before I replaced my clutch last year.
4-speed
3:54 Dana
Re: Vibration Question [Re: 70sixpkrt] #987626
05/07/11 06:20 PM
05/07/11 06:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I had a flywheel that was knocked out of balance because whoever cut it cut it wrong , it was .030 thicker on one side vs. the other.
You should have had the balance of the wheel checked after it was surfaced .
Re: Vibration Question [Re: 70sixpkrt] #987627
05/07/11 08:11 PM
05/07/11 08:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
So, are you saying that it does not vibrate while slowing UNTIL you disengage clutch disc?
Re: Vibration Question [Re: buildanother] #987628
05/08/11 02:39 AM
05/08/11 02:39 AM
Yes. It does not vibrate until I push the clutch pedal to the floor.
4-speed
3:54 Dana
Re: Vibration Question [Re: 70sixpkrt] #987629
05/08/11 09:36 AM
05/08/11 09:36 AM
JohnRR Offline
JohnRR  Offline
What type of clutch ? Pop the cover off and look at the throwout bearing and see if it is off center of the clutch fingers ?
Re: Vibration Question [Re: 70sixpkrt] #987630
05/08/11 10:15 AM
05/08/11 10:15 AM
chicagoland,usa
chicagoland,usa
Are you very certain that the u-joints are secured and centered? If so, make sure the 4 trans bolts are tight in bellhousing.
Re: Vibration Question [Re: buildanother] #987631
05/08/11 01:04 PM
05/08/11 01:04 PM
It's a Mcleod Borg and Beck clutch. The u joints are centered and all bolts are tightened.
4-speed
3:54 Dana
Re: Vibration Question [Re: 70sixpkrt] #987632
05/08/11 09:21 PM
05/08/11 09:21 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
When you pulled the drive shaft did you mark it's phase with respect to the rear diff? How bad is the vibration...teeth shaking or just noticeable?
Re: Vibration Question [Re: Jeremiah] #987633
05/09/11 09:33 AM
05/09/11 09:33 AM
No I did not mark its place and it is not teeth shattering but very noticeable.
4-speed
3:54 Dana
