bronze drive gear/roller cam break in #987559
05/07/11 11:41 AM
05/07/11 11:41 AM
Idaho
boomerodell Offline OP
Idaho
Got my parts for new roller swap yesterday to finish things up. The comp bronze drive gear didn't come with anything to attach it to the oil pump shaft, I'm assuming I can just get a roll pin and stick in there or something else? Also how important is cam break in for a roller lifter? Same break in procedure as a flat tappet? Its a big block. thanks
Re: bronze drive gear/roller cam break in [Re: boomerodell] #987560
05/07/11 11:49 AM
05/07/11 11:49 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
becarfull putting that gear on a stock oil pump drive if you have a hi volume pump you want to get the milodon or Mopar performance bronze gear and hardend one piece shaft .
the stock one is not as strong .
1969 Dodge Charger 1969 Dodge Superbee
Re: bronze drive gear/roller cam break in [Re: cjs69mope] #987561
05/07/11 11:57 AM
05/07/11 11:57 AM
Idaho
Idaho
It is a mopar performance shaft. I just figured the bronze gear would have came with more than just the gear. Thats what I get for thinking.
Re: bronze drive gear/roller cam break in [Re: boomerodell] #987562
05/07/11 02:07 PM
05/07/11 02:07 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
None, no cam break in with rollers
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: bronze drive gear/roller cam break in [Re: boomerodell] #987563
05/07/11 02:25 PM
05/07/11 02:25 PM
Idaho
Idaho
Thanks for the replys. Just got the steel gear off and damaged the shaft. Probably be the best to buy one already assembled.
Re: bronze drive gear/roller cam break in [Re: boomerodell] #987564
05/07/11 02:35 PM
05/07/11 02:35 PM
Hermiston Oregon
mopar_leaner Offline
Hermiston Oregon
mine cost me like $70 bucks and it was worth every penny! my engine made 600 hp!
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: bronze drive gear/roller cam break in [Re: mopar_leaner] #987565
05/08/11 11:14 AM
05/08/11 11:14 AM
San Jose,CA
Gunmetal Offline
Gunmetal  Offline
San Jose,CA
You got the bronze gear and hardened shaft for $70? Where did you buy it? I buy mine from Summit and they're about $110. Please share your secret.
Re: bronze drive gear/roller cam break in [Re: Gunmetal] #987566
05/08/11 11:57 AM
05/08/11 11:57 AM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
I think the 440source one is around $70
