Re: Driveshaft Question
[Re: JoesMopar]
#987466
05/07/11 01:58 AM
05/07/11 01:58 AM
RapidRobert
There's so many variables from the stackup of tolerances in the driveline that you'd want to mock it up (yoke all in/measure C to C /subtract 3/4") & go from there.
[Re: JoesMopar]
#987468
05/07/11 09:24 AM
05/07/11 09:24 AM
RapidRobert
In your situation I'd mockup/cut the longer shaft that you have on hand & you'll b fine w your mild 383 & it'll get you up & running quicker (or on to the next prob quicker). EDIT to ans your Q mockup that other shaft & post how much clearance you get
[Re: JoesMopar]
#987471
05/07/11 09:58 AM
05/07/11 09:58 AM
RapidRobert
You'll need to grab a 727 yoke & just check the inside to inside measurement between the ears on it & want 3&1/8 (7260) or 3&5/8 (7290) to match the same dimention on your intended shaft. iirc 4 sp yokes are the same (as a 727) but cant confirm that as I am not a 4 sp guy
