Car overheats when going upgrade. Head gasket? #986647
05/05/11 04:26 PM
05/05/11 04:26 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
I am having a new cooling problem with my car. It's a 1968 C Body with stock 383. A few months back the fan hit the radiator, causing it to leak, and the car overheated pretty bad. So I replaced the radiator with an aluminum one from summit. Now the car runs nice and cool in most situations. However, when I start going up a hill, like climbing a grade on the freeway, the temp gauge starts to climb. This is regardless of outside tmperature or vehicle speed, so this happens even when it's cold and I'm driving quickly. I am wondering if maybe I have a slight head gasket leak, and so when combustion pressure increases over idle/cruise, it pressurizes the cooling system and causes overheating.
Thoughts?
"Broke is temporary, cheap lasts forever"
Re: Car overheats when going upgrade. Head gasket? [Re: 68Bullet] #986648
05/05/11 04:53 PM
05/05/11 04:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
i'D DO A COMPRESSION CHECK ON IT FIRST.
Re: Car overheats when going upgrade. Head gasket? [Re: Challenger 1] #986649
05/05/11 05:00 PM
05/05/11 05:00 PM
MD-USA
Dodgeguy101 Online content
Dodgeguy101  Online Content
MD-USA
My guess or 2 cents is the cooling system is marginal and when you put a strain on it, it starts to overheats. Maybe that radiator isn't as good as the one you had. Not sure, just throwing it out there.
Re: Car overheats when going upgrade. Head gasket? [Re: Challenger 1] #986650
05/05/11 05:01 PM
05/05/11 05:01 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
x 2 on compression check. Also ....see if the cooling system holds pressure also.
Re: Car overheats when going upgrade. Head gasket? [Re: dOc !] #986651
05/05/11 08:45 PM
05/05/11 08:45 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
Would the compression check indicate that leakage into the water system is occuring? Or prove that maybe I got a few bum cylinders, which require more fuel to produce work, and thus add too much heat to the system?
Re: Car overheats when going upgrade. Head gasket? [Re: 68Bullet] #986652
05/05/11 08:48 PM
05/05/11 08:48 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Do you have bubbles or contaminates in the coolant?
Re: Car overheats when going upgrade. Head gasket? [Re: dOc !] #986653
05/05/11 10:03 PM
05/05/11 10:03 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Its without question a radiator problem. The new radiator cant keep up with the demands of the engine.
I would verify ignition timing however...
None of those radiator will cool as well as a factory HD 3-4core unit. Most of the aluminum radiators arent very thick...
How many cores does it have? Whats size is the radiator? How wide are the cores rows?
Re: Car overheats when going upgrade. Head gasket? [Re: 68Bullet] #986654
05/05/11 10:07 PM
05/05/11 10:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
How is the water pump and thermostat??
Re: Car overheats when going upgrade. Head gasket? [Re: 68Bullet] #986655
05/05/11 10:42 PM
05/05/11 10:42 PM
Missouri
convertriple Offline
super gas
super gas
Missouri
Sounds simple, but I would park it on a pretty steep uphill grade. Then check the antifreeze level while running (be careful as usual) and make sure it is full and you don't have an air pocket occuring. Basically make sure the system is "burped".
Re: Car overheats when going upgrade. Head gasket? [Re: 68Bullet] #986656
05/06/11 10:08 AM
05/06/11 10:08 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I "assume" you are using a thermostat.
Re: Car overheats when going upgrade. Head gasket? [Re: 62maxwgn] #986657
05/06/11 10:11 AM
05/06/11 10:11 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
I say headgasket or cracked head...
Re: Car overheats when going upgrade. Head gasket? [Re: CokeBottleKid] #986658
05/06/11 07:14 PM
05/06/11 07:14 PM
Oakland, CA
68Bullet Offline OP
68Bullet  Offline OP
Oakland, CA
It's got a new water pump and new 180° thermostat. I could definitely try to park it on a hill and see if possibly an air bubble. I agree that a factory 4 core is probably better, but the original radiator was the tiny 18" 2 core. Not adequate to start with.
Re: Car overheats when going upgrade. Head gasket? [Re: 68Bullet] #986659
05/06/11 08:10 PM
05/06/11 08:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Does it have a thermostatic fan clutch? If so, does the fan clutch engage when it gets warm? Anything showing up in the oil? Any bubbles in the coolant when warm, cap off, looking into the radiator? Is the cap holding pressure? Did you check the thermostat in some hot-to-boiling water before installing it? I've had lazy or just plain "bad" thermostats.
Re: Car overheats when going upgrade. Head gasket? [Re: topside] #986660
05/06/11 08:56 PM
05/06/11 08:56 PM
organ
maximum entropy Offline
organ
if it is a head gasket leak, you can typically smell exhaust in the coolant. an old mechanic's trick. you'd be amazed at how many times a car comes into our shop after having been all over town, and we have a diagnosis in five seconds. if it isn't the head gasket, it's probably inadequate cooling capacity (radiator).
Re: Car overheats when going upgrade. Head gasket? [Re: maximum entropy] #986661
05/07/11 04:45 AM
05/07/11 04:45 AM
Woodburn Oregon
Two Lane Offline
Two Lane  Offline
Woodburn Oregon
had the same thing happen on a customers 66 Fury with a 383. Exception being the radiator wasn't replaced. Turns out the block was full of debris from over the years that the block was full up to the bottom of the freeze out plugs!
