PS Pump (Federal) Pulley #985920
05/04/11 07:43 AM
05/04/11 07:43 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
I've got a NEW Federal pump for my 440 (Auto Zone). The problem is that the pulley I took off the old pump has too BIG of a hole. Not sure why the shaft on the new pump is smaller .
Is there a press-on adapter available for this or do I need to find a new pulley? Is there anyone that might have these in-stock? What other pulleys might fit (i.e. GM, aftermarket, etc...)? Trying to get the car on the road this weekend .
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: PS Pump (Federal) Pulley [Re: Plum440] #985921
05/04/11 11:33 AM
05/04/11 11:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no spacer , you were given the wrong pump from the zone , there is 2 different output size federal pumps , as you have found out . Bouchillon may have the correct pulley for that pump.
