Re: Pics of Indy intake.
[Re: 383man]
#985844
05/04/11 02:51 PM
05/04/11 02:51 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Don, As I said in the PM, the 337 may be a good option because it will clear your hood PLUS MP doesn't cast the runners to full MW out of the box, they're closer to 1/2 way between a standard BB ~2.27 x 1.13 port and a 2.6 x 1.3 max wedge. as I said I take HSD's out bigger than the 337 is out of the box. You wouldn't have to open up your Stealth heads much to match the 337...if you can't get Mancini or indy to do you right and get you a good 2D intake to replace the defective one,....assuming you haven't it!
[Re: 383man]
#985846
05/04/11 05:27 PM
05/04/11 05:27 PM
Posts: 8,896 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I don't know what the issue is with the Indy QC issues, maybe we should get someone from Indy to Represent here
Good luck with that, those guys border on being plain ol' ignorant! When you talk to them they make you feel like you're bothering them!
[Re: Stanton]
#985847
05/04/11 05:35 PM
05/04/11 05:35 PM
Posts: 740 Anderson, IN
1969RR
Anderson, IN
Yea, good luck with them! I made 3 trips to Indy, because they forgot to give me all the nec. parts for my EZ heads...and it was my fault! I was even told to my face "your wasting your time" asking about a stroker kit. I was hoping they would help me decide the correct one to buy. Jeff
[Re: Stanton]
#985848
05/04/11 05:36 PM
05/04/11 05:36 PM
Streetwize
Weddington, N.C.
Well i'm thinking there's enough Indy dealers here, Since they are a Mopar driven company if enough Moparts dealer network people get together and tell them they got a problem they better adress..... I don't mind bothering people...when the cause is in the right Some people really NEED to be bothered on occasion to get their in If mediocrity is tolerated that's all you're ever going to get!
[Re: Streetwize]
#985849
05/04/11 06:47 PM
05/04/11 06:47 PM
Posts: 2,468 Sydney,Australia
tex013
Sydney,Australia
looks real good Ron.now all you need to do is finish it and get it running Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#985850
05/04/11 07:43 PM
05/04/11 07:43 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I think that you would have already mentioned it, but has there been any milling done on your block or on your heads? I have the same intake on a pair of SRs and I don't have this clearance issue (I don't have the valley plate with the window because I'm cheap and like to spend ridiculous amounts of time swapping cams). It is a tight fit on mine, but I would've thought that with the clearance would have been better with the windowed valley plate.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: Stanton]
#985853
05/05/11 01:28 AM
05/05/11 01:28 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
What did you cut that with? Nice ports !!!!
I used my air wizzer with a 4" carbine cutting wheel. Worked like a champ. Now I have to smooth it over and paint it again. Ron
[Re: JohnRR]
#985856
05/05/11 12:22 PM
05/05/11 12:22 PM
383man
Balt. Md
The paint is Dupli-Color and the can says Chrysler Hemi orange. Thanks for the reply's. Ron
[Re: 383man]
#985858
05/06/11 12:38 PM
05/06/11 12:38 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Thanks Ron , I wonder how that compares to the plastikote hemi orange , Now I have to find a can ...
[Re: Mopar-Al]
#985860
05/09/11 10:06 AM
05/09/11 10:06 AM
383man
Balt. Md
not sure why you didnt bother to answer my question, but it's alright.
Sorry I must have forgot. No the top is not drilled for both carb setups. I would have to use an adapter to run a dominator. I will have to use my 850 DP to start with until I can get another carb. Ron
