Fusible link vs inline fuse #985060
05/02/11 08:03 PM
05/02/11 08:03 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I am re-wiring my Challenger and want to add an inline fuse to replace the fusible link (at starter relay to switch).
What rating is the link, or what amp rating fuse should I use?
Car has A/C and stereo (CD but no big speakers...).
--I have upgraded the wiring to eliminate the ammeter---so, Is this the ideal placement of the fuse (the original was from Ammeter to starter relay)?
Re: Fusible link vs inline fuse [Re: jsully] #985061
05/02/11 08:31 PM
05/02/11 08:31 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The name "fusible link" is a little misleading...It's really not a fuse...It will tolerate more of a load{and longer} than a real fuse...And that's where the problem with just switching to a normal fuse begins... The link is more of a last resort on keeping the wiring harness from roasting and was never intended to have a real inline fuse in that position...I'd keep the link...
Re: Fusible link vs inline fuse [Re: jsully] #985062
05/02/11 08:36 PM
05/02/11 08:36 PM
IMGTX Offline
IMGTX  Offline
Fuses burn fast but a fusible link is slower to burn so it takes power surges better. I suggest you keep the fusible link but if you insist Start with 30 amp but expect it blow and need to be 50.
Re: Fusible link vs inline fuse [Re: jsully] #985063
05/02/11 09:04 PM
05/02/11 09:04 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Most good auto electric shops carry fusible link wire. 4-6 inches should be enough, probably 14 gauge.
Re: Fusible link vs inline fuse [Re: 5spdcuda] #985064
05/02/11 09:06 PM
05/02/11 09:06 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
x 2 .....KEEP the fusible link ..
Re: Fusible link vs inline fuse [Re: dOc …] #985065
05/02/11 09:46 PM
05/02/11 09:46 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I appreciate the info, I did not understand the original usage.
I will go to the parts (napa) store to replace the link.
Also- Should I add a fusible link inline from the alternator to the starter relay (new routing)?
Re: Fusible link vs inline fuse [Re: jsully] #985066
05/02/11 09:53 PM
05/02/11 09:53 PM
Yes, Std procedure is FL 2 sizes smaller than what it's protecting & an 8 ga would be a good size for that bypass line and a 12 ga FL at the alt output stud. Nacho's tip: keep the ammeter as close to 12 o'clock as possible but moot point 4 you as you are bypassing
Re: Fusible link vs inline fuse [Re: jsully] #985067
05/02/11 09:54 PM
05/02/11 09:54 PM
IMGTX Offline
IMGTX  Offline
My preference is to have a fusible link at the Alternator and at the battery.
The factory didn't have one on the alternator but if the voltage regulator goes bad or a wire shorts a field to ground and it goes full charge it will toast the wiring the same as a shorted wire.
DAMHIK.
Having one at both voltage sources protects your wiring.
Re: Fusible link vs inline fuse [Re: IMGTX] #985068
05/02/11 10:30 PM
05/02/11 10:30 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a 100a marine circuit breaker for my charging system (higher amp alt). I prefer it, it's tripped once in the four years it's been on there. I rather just click it back over, much better than a fuse..easier to work with than a fusible link...in my opinion
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Fusible link vs inline fuse [Re: GoodysGotaCuda] #985069
05/02/11 11:41 PM
05/02/11 11:41 PM
What brand/part # as I have a 100amp alt ready to go (the one w the vanes) and what amp would you suggest for a regular type alt (60-78 amp). Brand/part # ? Way back I had a near dead short develop for a short time (alt prob iirc) & it melted the insulation severly on the main in/out lines but the FL did not blow & the system still worked & I didn't catch it till I opened the hood and saw the melted insulation.
Re: Fusible link vs inline fuse [Re: RapidRobert] #985070
05/03/11 12:25 AM
05/03/11 12:25 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
actually the fuse link will protect the short from BATTERY never from alt. The batt is the only source able to KEEP the short being feeded. If you were running just sourced from alt, the engine will stall on the first instance of the short and that will kill the short instantly, even with 100 amps.
The increased fuse link gauge would be just to support the increased load when a death battery. Bigger alt and death batt will mean the alt will feed and recharge faster the batt with more load. BUT hardly will suck 100 amps unless you rev up hard the engine. That will mean the fuse link will hardly receive the 100 amps load.
14 gauge fuse link will be just fine even with 100 amps alt.
You can increase the load protection BUT you can't go to the extreme because if you get a short, fuse link will never burn, or will take too much time to burn, and damage will be bigger on the short area before the fuse link blows out completelly. Better smaller than bigger on this case.
In Line fuse is a good idea, IF you over rate the fuse to be able to support a peak/surge.
Re: Fusible link vs inline fuse [Re: RapidRobert] #985071
05/03/11 12:25 AM
05/03/11 12:25 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
It's a blue sea systems brand, has two ~1/4" or so lugs on it for your power to run through. I used to have pictures of all that stuff, however I'm not sure where they ran off to. Bought it off the net for much cheaper than a place like West Marine would have it for. Amazon is $36 for an 80amp
http://www.amazon.com/Thermal-Circuit-Br...3086&sr=1-1
I'm very happy with how it seems to be doing, just something I never think about really.
2020 RAM 1500
Re: Fusible link vs inline fuse [Re: GoodysGotaCuda] #985072
05/03/11 12:38 AM
05/03/11 12:38 AM
Nacho that makes sense and Goody I'll check into prices/avail.
Re: Fusible link vs inline fuse [Re: RapidRobert] #985073
05/03/11 02:59 AM
05/03/11 02:59 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When cars started using Power Distribution Centers under the hood the very large fuse looking links replaced the fuse links on the cars. You might find a fuse link in certain circuit on a new car but I cant think of any. The ones I mean are the ones under the hood in the PDC that look like a giant plastic 2" fuse and many of them bolt in with eyelets on both ends but some are push in. When I put my battery in the trunk I made a few changes and use 2 of the PDC type fuse links and I have never had one blow out. I use a 60 at the alt and a 80 at the battery. When I put my battery in my trunk I did not want the battery cable hot unless the car was cranking as I run it under the carpet. So I used a Ford type solenoid in the trunk to keep the battery cable dead other then starting and I ran a 10 gauge wire from the battery to the factory starter relay where the car picks up all the hot battery feeds. I put the bolt in 80 amp fuse link right at the battery cable. Like I said I have never had any trouble with this setup at all. Ron
