Which 440 should I build #984562
05/02/11 01:46 AM
05/02/11 01:46 AM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I have 3 complete 440 motors but I don't know which one I should rebuild.
1. Is a 78 motor home motor which had 48,000 miles on it it has a cast crank and the goofy motor home heads on it but I have a set of 906's for it. I don't know much more about this motor
2. Is a 75 440 Hp motor it has a newish looking set of 906's on it and it's also a cast crank motor. I have the top end taken off of this motor. I was just inspecting it but found a pretty good ridge on the top of the bores and some scratches in the bores that I don't like. This motor ran fine didn't smoke and had decent oil pressure before I pulled it out of the car.
3. Is a 67 440 with a forged crank and 915 heads. I don't know much more about this motor.
The car one of these motors will go in is a 73 Roadrunner the car will just be a mild cruiser just a car that's fun to drive around so I'm not after a mountain of horse power. Help me pick the best/ cheapest motor to rebuild out of these 3. My thoughts are to just rebuild the one I have on the stand ( The 75 hp motor ) and sell the other two to help pay for the rebuild.
Re: Which 440 should I build [Re: Boise Chall] #984563
05/02/11 01:53 AM
05/02/11 01:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
For a good cruiser with decent power, you will at least be honing the block and replacing the rings, right? The '67 motor will offer the most compression of the 3. The motor home mill likely has LESS than 7.8 to one squeeze. Certainly a durable mill, but waaaay low on compression with pistons .120 down the hole. The '67 motor will likely have near 10 to one and with a decent cam, can run strong on mid grade fuel. With new rings, you ARE going to get a valve job, right? It makes sense to install new springs as well. 44 year old valvesprings on a higher lift new cam..... not good.
Re: Which 440 should I build [Re: Kern Dog] #984564
05/02/11 02:00 AM
05/02/11 02:00 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Kinda boils down to if the '67 needs pistons. That would be the best motor for making power what with the forged crank & 915s, but the MH motor with 906s and some pistons would make a good cruiser. If the 75 bores can be cleaned up, obviously it'll need pistons. The '67 is the most valuable of the 3.
Re: Which 440 should I build [Re: topside] #984565
05/02/11 02:25 AM
05/02/11 02:25 AM
Boise Idaho
Boise Idaho
I'm sure all 3 will need pistons considering their age and compression. The one I have one the stand was the one I thought would have the best chance of being usable because it was running and it was only supposed to have 2,000 miles on it. I'm sure it only had 2,000 miles on it 50,000 or 100,000 miles ago. With the market in the condition it's in what's a complete carb to oil pan 67 440 worth ?
Re: Which 440 should I build [Re: Boise Chall] #984566
05/02/11 12:29 PM
05/02/11 12:29 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
If it were me, I'd want to use the forged crank and 915 heads.
Re: Which 440 should I build [Re: rss] #984567
05/02/11 12:46 PM
05/02/11 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No matter which block he starts with , the later blocks would be my choice , if you are set on using stock iron heads then I use the 915 heads.
Re: Which 440 should I build [Re: JohnRR] #984568
05/02/11 01:07 PM
05/02/11 01:07 PM
Boise Idaho
Boise Idaho
The 915 heads look original so they wouldn't have the hardened seats in them right ? the 906's look like they have had some work done to them recently how can I tell if they have hardened seats in them ? 10 years ago I would have just taken the motor that's on the stand now painted it and ran the crap out of it but I just can't do it now.. Did I grow up ?
Re: Which 440 should I build [Re: Boise Chall] #984569
05/02/11 01:23 PM
05/02/11 01:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The added cost of putting seats in the 915's is minimal in the big picture of the rebuild. The 906 is an open chamber head , not the perfect choice especially since you have the 915's .
Are you going to be putting 20k miles a year on the car ?
Re: Which 440 should I build [Re: JohnRR] #984570
05/02/11 01:47 PM
05/02/11 01:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd use the best parts from all 3. Ideally you'd want to use the 67 block and heads. If you are going to buy all new guts I'd use the block/heads that require the least amount of machine work. Hard to say w/o seeing all of it.
Coming soon!!!!
Re: Which 440 should I build [Re: Mr.Yuck] #984571
05/02/11 01:50 PM
05/02/11 01:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you think he should use the best of all 3 what leads you to believe the 67 block is BETTER than the others ?
Re: Which 440 should I build [Re: JohnRR] #984572
05/02/11 01:52 PM
05/02/11 01:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
meaning if the bore on the 67 didn't require bore and new pistons I'd use that.
Re: Which 440 should I build [Re: Boise Chall] #984573
05/02/11 02:18 PM
05/02/11 02:18 PM
scratchnfotraction Offline
what goofy MH heads do you refer too?
#452 with the small peanut 5/8 spark plug?
thats whats on mine and works fine fora stock street engine,it has better cooling pasages with harden seats. IIRC
are you talking baout the heads like on a 413 with the WP housing bolted to the end of the heads?
Re: Which 440 should I build [Re: Boise Chall] #984574
05/02/11 02:28 PM
05/02/11 02:28 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
More patient, for sure. Back in the day, a guy didn't have money or time to build the perfect scenario. Its this type of issue that stalls a project out for too long. Slap the 'MoHome' mill in while you take the time to build a good one.
Re: Which 440 should I build [Re: Boise Chall] #984575
05/02/11 02:33 PM
05/02/11 02:33 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Use the forged crank, 915 heads and whichever block checks out the best......no real world advantage or disadvantage to any particular block choice.
If they were all mine, I'd plan on using the 67 block just so I wouldn't need to totally disassemble the other two motors, If it checks out, great....if not, check the next 440 block in line.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Which 440 should I build [Re: Boise Chall] #984576
05/02/11 03:59 PM
05/02/11 03:59 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
You should be able to see where the seat area has been machined and a hardened seat has been pressed in. I'd imagine it might be difficult to see on a used head with some carbon build up. If hardened seats were installed, it will probably only be on the exhaust valves.
Re: Which 440 should I build [Re: scratchnfotraction] #984577
05/02/11 04:06 PM
05/02/11 04:06 PM
Boise Idaho
Boise Idaho
The motor home heads that I have are the ones that have the peanut plugs. The water pump is the normal car/truck water pump. I'm just nervous about the motor home motor because it's a 78 with 48,000 miles on it so it's done alot of sitting around and the low compression.
Re: Which 440 should I build [Re: Boise Chall] #984578
05/02/11 04:17 PM
05/02/11 04:17 PM
michigan woods
imfixinmopars426 Offline
michigan woods
another vote for using the best stuff from the 2 or 3 engines.
Re: Which 440 should I build [Re: Boise Chall] #984579
05/02/11 05:06 PM
05/02/11 05:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
nothing wrong with those heads , I just finished up a build using them. I bought them from Paul Rossi back in the late 80's and the build I did used a 77 block that had the matching holes in the block for the coolant to flow across the chamber to help keep things cool.
That aside the 75 HP should have the same low compression pistons as the motorhome engine so even with the 915's on it you'll have a low compression engine, if you are going to plan on new pistons and doing a full rebuild get a piston near zero deck , use the 915's with a basic rebuild , a little bowl work will help , keep the compression about 9.5 and you should run on pump 89 with no problem .
Re: Which 440 should I build [Re: imfixinmopars426] #984580
05/02/11 06:05 PM
05/02/11 06:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Me too! the advantage of the two newer blocks they have the stiffening rib up the side of the blocks that help with an early block tendency to crack between the frost plugs.
steel crank, new pistons, 906 or the 516 heads or better sell both and get aluminum!!!!!!!!!!!!
Re: Which 440 should I build [Re: JohnRR] #984581
05/02/11 06:48 PM
05/02/11 06:48 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
a little blow work will help ,
Please tell me that this is a typo.....
