For PT Cruiser Owners #983499
05/01/11 12:02 AM
05/01/11 12:02 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Buddy has a 2006 PT vert. Is running aftermarket 17" wheels and tires. When driving down the road he sometimes gets a shimmy when he hits a bump. Sounds to me he's getting some steering deflection. Is there a kit that ties the front end together or is there a sway bar made for the PT's that addresses his problem?
Re: For PT Cruiser Owners [Re: dart4forte] #983500
05/01/11 12:08 AM
05/01/11 12:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Look for worn parts, Bent wheels, tire and wheel run out and lateral movement, balance and alignment.
Re: For PT Cruiser Owners [Re: NITROUSN] #983501
05/01/11 12:41 AM
05/01/11 12:41 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The most common front end problem on them (have not had this myself) is the lower ball joint.
Re: For PT Cruiser Owners [Re: RodStRace] #983502
05/01/11 12:45 AM
05/01/11 12:45 AM
Mesa, Arizona
Mesa, Arizona
Yes, I see a lot on the internet that addresses lower ball joint problems. I just found a TSB that addresses a problem with the struts. There was a suspension recall for 2005 and 2006 Cruisers
Re: For PT Cruiser Owners [Re: dart4forte] #983503
05/01/11 12:57 PM
05/01/11 12:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can get some good info at www.PTCrew.com
Re: For PT Cruiser Owners [Re: stumpy] #983504
05/01/11 11:20 PM
05/01/11 11:20 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
lower control arm bushings are also a problem
