68 Charger single to dual field conversion #983414
04/30/11 10:22 PM
04/30/11 10:22 PM
Sonoran desert, Arizona, USA
moparjo68 Offline OP
Hello. Would love to chat with a 68 Charger owner who has updated their charging system from old volt. reg. and single field alt to the '70 charging system. I have the components for the switchover (brand new '70 volt. reg. with the 2 wire plug in, 60amp dual field alt.) but I am having technical difficulties in getting system to now charge.
Question #1: The original green field wire goes to the green wire on the newer '70 volt. reg. plug. Where does the other field wire connect to? Does it HAVE to be grounded to alt or can it hook up somewhere and be functionable?
Question #2: The '68 Charger has a drk bl wire and a drk bl wire w/tracer going to ign side of old volt. reg. Do these two wires now go to ign side of newer '70 volt. reg.?
In the near future, I will purchase the new wiring harness from Y.O. but for now, can someone out there who's been down this road steer me in the right direction for now? Thanks so much, Joe
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983415
04/30/11 10:54 PM
04/30/11 10:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You dont ground it. It is keyed 12 volts. The blue wire to the regulator is the same circuit to the alternator.
As long as they are keyed 12 volts yes.
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983416
05/01/11 12:37 AM
05/01/11 12:37 AM
run the dark blue/ blue w tracer wires to the "ign" terminal on the v reg which is the "top" terminal in the triangle w it "up" like a pyramid and T off of this line to either alt field terminal. The OE green wire, run it from the other alt field terminal to the "side" terminal in the triangle. You can trim the sides of a '70 up flat v reg & it will nestle neatly in the squarish firewall recess where the OE mechanical "box" type resided & redrill 1 hole on one of the sides of it
Re: 68 Charger single to dual field conversion [Re: RapidRobert] #983417
05/01/11 01:27 AM
05/01/11 01:27 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You could run the old reg and ground the second field just to get going again.
Re: 68 Charger single to dual field conversion [Re: RapidRobert] #983418
05/01/11 02:01 AM
05/01/11 02:01 AM
I took the two wires.........the dark bl and dark bl w/tracer and connected to inside terminal of new reg (ign side). I also connected new field wire to this same terminal. OE field wire is connected to outside terminal of new reg(field side). It was charging before the switch.......now its not. I wonder what I did wrong???????
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983419
05/01/11 09:45 AM
05/01/11 09:45 AM
When you say "inside" terminal you mean the top one in the pyramid right?. Might full field the alt; take both field wires off of it/eng at a fast idle/w (2) jumper wires jump one alt male field to batt positive post and jump the other alt male field terminal to ground for several seconds MAX. this'll tell you if the alt is good as from your descrip the wiring sounds correct unless I'm missing something. You'll hear the eng slow down slightly from the max load if the alt is putting out a good charge
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983420
05/01/11 12:10 PM
05/01/11 12:10 PM
to clarify, it was charging w the early OE box reg/single field terminal alt, & you upgraded to a later 2 field terminal alt/flat '70 up reg w triangle connector?
Re: 68 Charger single to dual field conversion [Re: RapidRobert] #983421
05/01/11 12:42 PM
05/01/11 12:42 PM
There are only two terminals on this '70 reg. Facing the reg., the left terminal has the two ign wires and new field wire attached to it. The right terminal has the OE field wire attached to it
Re: 68 Charger single to dual field conversion [Re: RapidRobert] #983422
05/01/11 12:45 PM
05/01/11 12:45 PM
Yes, the system was charging with the old volt reg, old one field alt. All connections are clean, tight, checked, rechecked and rechecked again.
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983423
05/01/11 01:36 PM
05/01/11 01:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
colored and edited diagram
Re: 68 Charger single to dual field conversion [Re: NachoRT74] #983424
05/01/11 01:45 PM
05/01/11 01:45 PM
Yes, that is how I hooked up new volt. reg and newer alt. So I am puzzled and frustrated that it doesn't charge.
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983425
05/01/11 03:23 PM
05/01/11 03:23 PM
"full field" the alt & if it's good then there's an open in the diagram Nacho posted for you, grab your meter
Re: 68 Charger single to dual field conversion [Re: RapidRobert] #983426
05/01/11 09:37 PM
05/01/11 09:37 PM
The alt checks out fine. I even have a spare alt and it checks out fine. I hooked the charging system back up to the old style black rectangular volt reg and single field alt. It now charges. But I want to convert over to the '70 charging system. I don't want to keep this setup.
Re: 68 Charger single to dual field conversion [Re: moparjo68] #983427
05/01/11 10:38 PM
05/01/11 10:38 PM
Make up some long jumper wires w alligator clips on each end (they come in very handy all the time) and jump directly to each connection/terminal duplicating Nacho's diagram & when (at a fast idle) you parallel jump the particular wire that has the open you'll hear the alt kick in then fix the open in that wire & unless there's been serious amperage that's cooked the copper inside or frayed/melted insulation on the outside (You'd visually spot that) or broken strands from excessive flexing (which is rare) wires do not go bad for no reason along their length but do so at the ends/connections so find the errant wire and check the end terminals/connections. EDIT unless the reg is bad but it is brand new & assuming it's grounded good. MORE EDIT w it all hooked up/fast idle, jump the alt male terminal (w the green wire) to ground & if it full fields then that only leaves the reg/reg ground/green wire as everything else is functioning good
Re: 68 Charger single to dual field conversion [Re: RapidRobert] #983428
05/02/11 05:51 PM
05/02/11 05:51 PM
Ahhhhhhhhhhh! It's a great day! Osama is dead and my Charger is charging with the '70 setup charging system. When you mentioned "grounding", I knew I had neglected this area. The '70 reg. has a beautiful THICK paint job and I took the Dremel and sanded off some of the paint. Now...........ITS CHARGING! Thank you thank you thank you for all your posts and help. Its a great day! Joe
