Re: rancho rear shock ?
[Re: a493demon]
#983325
04/30/11 08:47 PM
04/30/11 08:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I think the ones you need are the 99113.I use the 99116 on my Demon,but I have super stock springs.
[Re: a493demon]
#983326
04/30/11 09:05 PM
04/30/11 09:05 PM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
i have cal tracs on my demon with the ranco shock i put on at the end of last year.today i had it at work driving thru the parking lot and it was very stiff. i looked under the car and the shocks were too long (bottomed out).so my ? is what length rear shocks are you using.this has the 1 under mono's on it.thanks brad p.s the number on the shocks is rs99116. [/quote
Thats strange, I have -1" split monos and the dr diff offset spring hangers in the top hole, which lowers the car another inch.
I have rs99116 ranchos and have one inch clearance from snubber on diff to the floor pan and about one and a half inches before the shocks bottom out.
My tailshaft would hit the floor pan before the shocks could bottom out.
[Re: a493demon]
#983331
04/30/11 10:17 PM
04/30/11 10:17 PM
572B1
Brisbane Australia
that's what happend i had +1 then switched too -1 .so now i will have new shocks and -1 springs for sale.lol.brad
When i ordered mine,there was only two types 99113 for a body and 99116 for e body cars. The company i bought mine off only had the 99116, so i used them.
I must have been lucky, i also have 1" lowering blocks as well and i have 1 1/2" clearance before the shocks bottom out.
Your car must sit really low, has it got sliders in the rear.
[Re: a493demon]
#983333
04/30/11 10:37 PM
04/30/11 10:37 PM
572B1
Brisbane Australia
no slidders.brad
Spring hangers in the factory location? and is there arch in the springs or are they flat.
[Re: a493demon]
#983337
04/30/11 10:59 PM
04/30/11 10:59 PM
Posts: 117 @ the shop
E-85 408 DART
@ the shop
Spring ride height: 1” low 1” high standard
A Body 99113 99116 call for tech assistance
B/E Body 99113 99116 call for tech assistance
Measurement required at static ride height – shock attachment point top to bottom
Measurement between 17 - 19 inches: use 99116 Measurement between 15 - 16 inches: use 99113
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
[Re: a493demon]
#983340
05/01/11 10:50 AM
05/01/11 10:50 AM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
We may both be in luck, if you want I have a set of NIB A body Rancho's I might trade you out for the B/E's.
But I may be able to use the A body length on my Rocky but I need to get up under there to see, I'll try to do that sometime today. I need a set of the long ones for my Charger though.
PM me if you're interested.
