Aligning Bellhousing with Engine on Stand?
#982569
04/29/11 02:48 PM
04/29/11 02:48 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
This weekend I want to install my flywheel and Quicktime bellhousing for my T56 installation on the 408.
The engine is out of the car on a stand. I was just going to hang it off of the Engine hoist, maybe set it down on the oil pan on the floor so I can install the flywheeel and align the bellhousing.
Does anyone have any tips or tricks on how to get this done? Thanks, Scptt
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Aligning Bellhousing with Engine on Stand?
[Re: Stanton]
#982572
04/29/11 03:16 PM
04/29/11 03:16 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
That'll work. The higher the better so you're not screwing your back bending over!
What he said , clear off a spot on the bench and put it that high if possible .
