Re: 70 b-body ignition key buzzer questions.
[Re: Airgrabber]
#981162
04/27/11 02:13 PM
04/27/11 02:13 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
the key buzzer SWITCH on 70s drives positive as far I could decode on diagrams.
The wiring coming out from column harness are RED and are using the ign switch plug... then becomes on other color.
you can unplug the ign switch harness and check for continuity between both tiny red wires at plug and will discard the sensor switch
