In a 10 to 15 second quarter-mile run,
when the vehicle speed is 20 to +90 mph
it is unlikely that even at full throttle output,
will the air going by the radiator
and hitting the viscous clutch bi-metallic spring
get hot enough quickly enough to lock it during the short run.
When you let off the throttle
and the vehicle slows down to 5-10 mph
for the return to the pits
then the delayed heat in the radiator will flow past the bi-metallic spring
and it will probably lock up the clutch
but the engine rpms will be low.
The horsepower a fan requires goes up so dramatically with rpm,
that there will be a rpm limit
at which it flies apart.
Yesterday I destroyed the little plastic propeller
in an $20 Eddie Bauer 'Weather Watcher' wind speed meter,
when I pressed it up against the nozzle of a wet-dry vacuum.
The wind speed went whizzing up to 100 mph on the digital display with a roaring noise,
... then 'Pop'
and the axle of the fan broke,
and now the little meter is only good for measuring air temperature.
I guess I will now have to spend $64
and buy a
Brunton ADC Summit wind speed meter,
but it might be a good upgrade
because it can also measure water speed
if you are in a kayak or canoe,
or want to measure the water coming out of
a large pipe.
http://www.amazon.com/Brunton-ADC-Wind-M...mp;sr=8-1-fkmr2You can use these inexpensive wind speed meters
to approximately answer the frequent forum question:
How many CFM does my radiator fan actually pull?
