stage VI and valley pan #978094
04/22/11 02:29 PM
04/22/11 02:29 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Ok I used a 440 source valley plate and was not digging how much selaer was required, now I have oil everywhere from the plate. Can I use the standard valley pan gasket w/ Stage VI heads?
Coming soon!!!!
Re: stage VI and valley pan [Re: Mr.Yuck] #978095
04/22/11 05:49 PM
04/22/11 05:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I like the aluminum valley tray with the removable cover.I think Andy F makes one and the removable cover was o-ringed so cam or lifter replacement is a breeze
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: stage VI and valley pan [Re: hemi-itis] #978096
04/22/11 05:59 PM
04/22/11 05:59 PM
AndyF Offline
AndyF  Offline
I do make two-piece billet valley plates, but I only make them for Indy heads. The Indy heads are designed to work with a valley plate. Some of the other heads don't work so well with a solid valley plate.
I recently made some clear center plates so we could take a look at some oil issues on the dyno. But this valley plate only fits the Indy heads. I don't think it would seal very well on the sides with a Stage VI head.
Re: stage VI and valley pan [Re: AndyF] #978097
04/22/11 06:15 PM
04/22/11 06:15 PM
hemi-itis Offline
hemi-itis  Offline
Andy,I just remember your plate because,,,,,,,,,,,,,that's the way they all should be,same with your t/c cover.I didn't even stop to ask what intake Mr Yuck was using.So what intake ARE you using??
