Re: Electric vacuum pump?
[Re: Eric]
#977759
04/21/11 10:55 PM
04/21/11 10:55 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I used to use the one off Corvettes.. They work good enough, but use quite a bit of battery power. Lots of amps.. I think they pull 8" of vacuum. Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Chris'sBarracuda]
#977760
04/21/11 11:14 PM
04/21/11 11:14 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Thanks Chris...I figured I would run it while I was going down the track and for a few minutes after the pass...I do run an alternator..watcha think?
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: dartman366]
#977764
04/21/11 11:42 PM
04/21/11 11:42 PM
Chris'sBarracuda
Arizona
Just get one @ a wrecking yard. 1995 up If I remember. I used to have the part number, but not any more. It is an air pump from Firebirds, Cameros, and Corvettes.. Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
#977767
04/22/11 12:33 AM
04/22/11 12:33 AM
Eric
Pittsburgh PA
You guys think it might help with the leaks?
[Re: Eric]
#977769
04/22/11 01:28 AM
04/22/11 01:28 AM
Chris'sBarracuda
Arizona
Yes. ![](/ubbthreads/images/graemlins/thumbs.gif)
