Re: K member tech- what do I have here?
[Re: gregn96cuda]
#977726
04/22/11 12:52 AM
04/22/11 12:52 AM
Posts: 572 Portland , Oregon, United Stat...
smokes
I looked at the k member and no holes in the front of it. It also does not have the center hole for the sway bar to pass through either. I am pretty sure my 69 charger I had did not have the front mounting holes either. Are the numbers on the left front engine mount the ones I need to look at to id it correctly?
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
[Re: Jim_Lusk]
#977734
04/23/11 11:26 AM
04/23/11 11:26 AM
smokes
So since I bought this for my coronet big block car I would just need to get a b body big block k member and the contol arms and brakes from this would swap right over because they are the same, correct?
[Re: smokes]
#977736
04/23/11 12:19 PM
04/23/11 12:19 PM
Posts: 8,501 Candler,NC / Myrtle Beach, SC
JDMopar
Kind of hard to tell exactly, but looking at the rotors...it appears to be from a 70-72 B or E-body. I say that because the rotors look like the 2 piece design.You can buy a spindle sleeve from Dr. Diff so that you can use the later 1 piece rotors that are a LOT cheaper and easy to get. So yes...the brakes will work. If it were me, I would make a way to get both k frames level (both ways)and check the angle of the steering box mount plate. I did that with a 70 Roadrunner k frame and a 70 Challenger k frame a few years ago, and there was 2 degrees difference in the angle of the box. I think the e body was 23 degrees, and the b was 25 degrees. Would that make a difference as far as wearing out steering column joints? People here have used different body style k frames in cars and didn't seem to have problems. Check around some more before you go buy another k frame. No need to worry about it being from a big block as long as it's from a V8 car. Unless it's a Hemi k frame, they will all fit big or small block. The difference is in the brackets that actually bolt to the motor. That's my , so good luck.
[Re: smokes]
#977741
04/23/11 11:08 PM
04/23/11 11:08 PM
smokes
So I scoured the k member for new numbers. I did not find anything in the front or the back but I did find some numbers on the top and the bottom. If you are looking down on it from the top right next to that tiny hole in the top of it that is covered by the oil pan it says M 1565. If you are looking up at it right next to where the two sheets of metal meet below the hole up top it says MK45-1 and LMK 45-1. Hope this rings a bell with someone!
[Re: smokes]
#977743
04/26/11 12:46 PM
04/26/11 12:46 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
any help ????
Yes , that is a 67-to early 69 B body K ... best I can tell from the blurry pictures ... it does appear to have the swaybar mount holes on the front lip ... best I can tell again blurry pictures. Someone swapped on the 70-72 B/E single piston brake setup judging by the rotrs ... 2 piece ??? and the pin type calipers , if so those rottors are hard to find an $$$. I think Dr. Diff sells a spacer so you can use the 73 up unicast rotor on that spindle .
I can't really tell if it's a small/big block or a slant 6 from those pictyures .
