help with Hemi crank measurement..
#976730
04/20/11 03:53 AM
04/20/11 03:53 AM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
I'm about ready to order my crank from Crower (having figured out the final weights, etc., with the help of everyone here. Thanks! ) Does anyone have the measurement from the crankshaft-flywheel mating flange surface - to - the rear block surface that the bellhousing bolts to? Also, if anyone has the thickness of the crank flange that may be useful to have in considering my measurements. Assume it's a standard style 8-bolt 426 Hemi crank. I have to order the crank drilled for a manual trans pilot (I have a T56), so I need to triple check the measurements as I don't have a crank to work with. I also have to consider the clutch dimensions so best if I can get as many measurements as I can now. Any help greatly appreciated. If you come up with different measurements it will just help me get an idea of contingency I have to build in to the depth of the drilling. Trans shaft extends 0.850 in from block/bell mating surface at present. cheers
-------------------------------- Darren Beale Keith Black Racing Engines®
Re: help with Hemi crank measurement..
[Re: Keith Black®]
#976731
04/20/11 05:29 AM
04/20/11 05:29 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
you will find that area having a standard measurement .I am sure that Crower has the on hand. what they would need to know otherwise would be when the crank is used for applications in custom where special multi disc clutches used in fuel cars.
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#976732
04/20/11 05:31 PM
04/20/11 05:31 PM
Keith Black®
QLD Australia
thanks Fred it'd would still be good to know the measurement if anyone has it handy, for my own piece of mind when ordering and cross-checking with crower. I don't have a reference crank unfortunately.
* measurement from the crankshaft-flywheel mating flange surface - to - the rear block surface that the bellhousing bolts to. help greatly appreciated
[Re: 23T Hemmee]
#976734
04/20/11 07:21 PM
04/20/11 07:21 PM
Keith Black®
QLD Australia
Hi Ronny, thanks it'd be great if you could.. no rush.easter break this weekend & we're heading away,so next week is ok. Decided on the billet crank EN30B knife edged. May be overkill (but way better than underkill). I posted a reply to the last post with the crower feedback included (sorry it took a while). They more-or-less reckon the forged would be alright for my app, but i'll play it safe as I don't want to tear the motor down that frequently to check. Thanks to your advice/help- I looked further and the Lightweight & Ultralightweight probably wouldn't work as you pointed out. Reasons being not so much the strength of the crank -considering a blower would be driven off the front it'd still be more than strong enough - but more to do with the steel rods & bobweight - it seems, depending on my final piston weights (which I don't know yet) that the bobweight could be in excess of 2,300-2,400 so the crank would need weight added negating the whole point/cost of a lightweight assembly anyway. That's where I got to so I'll stick with a high grade/quality billet and hope it'll last forever. appreciate your help.
[Re: HEMIFRED]
#976736
04/21/11 06:01 PM
04/21/11 06:01 PM
Keith Black®
QLD Australia
thanks Fred i have checked with crower they only have the rear thrust face to flywheel flange face measurement.
[Re: Keith Black®]
#976737
04/22/11 02:40 PM
04/22/11 02:40 PM
Posts: 25,941 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The measurement from the Hemi flywheel mating flange surface to the rear block surface will be the same as any '62-later Wedge or LA SB.
[Re: HEMIFRED]
#976739
04/22/11 07:17 PM
04/22/11 07:17 PM
Keith Black®
QLD Australia
I'm running a T56 Magnum transmission, which has a non-mopar input shaft diameter & depth. I don't have a crank to baseline the measurements off. I was hoping someone would have a RB/Hemi where they could take a quick measurement so I can calculate the actual depth (from that surface) that I need to have the crank drilled to for the input shaft. I don't want the input shaft to interfere with the crank when it's all bolted up.
[Re: Keith Black®]
#976740
04/22/11 07:26 PM
04/22/11 07:26 PM
Keith Black®
QLD Australia
Fred, the only reference measurements I can take is from the rear engine/bell mating surface -where the transmission input shaft extends 0.850in. forward of this surface. This is only a block based measurement & I need a crank based measurement to spec/order the crank. the best measurement for me will be the flywheel flange to block/bell surface.
[Re: rowin4]
#976748
04/30/11 08:52 PM
04/30/11 08:52 PM
Keith Black®
QLD Australia
the crank has to be made anyway (billet), so I may as well get the spec right to begin. I don't want to mess with the T56 as it is. It may well be that the crank doesn't need drilling any deeper than std, i just need reference measurements. thanks
