Re: 383 Piston/Rod Combos - Am I Missing Something???
[Re: rss]
#976692
04/23/11 11:38 AM
04/23/11 11:38 AM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Better off pricewise to go with a Diamond distributor. There are a few on this site. I went with PerformanceOnly for pistons for my 361, the real redheaded stepchild!, and Dan did a great job for me. The knowledge these distributors have is amazing. CompetitionWedge is another one. Pat
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: rss]
#976694
04/27/11 11:32 AM
04/27/11 11:32 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
since the 383 is the redheaded stepchild of the big block wedge family those that do build them want a set of pistons for less than a cup of coffee .
Not looking for a cheap piston, but it doesn't seem you should have to go custom just to get a flat top with a decent compression height and is compatible with the current selection (1) of aftermarket rods. Diamonds normally run about $650 a set, so what does a custom set go for $750 or more? Seems hard to justify to warm up a 383 for your street cruiser. Guess that's why most are using KB400s with a dome.
Since they mostly make high-end stuff for performance applications, not sure that I understand why Diamond makes makes theirs with a 1.916 CH.
Then, on the other side of the equation, we have one option for forged rods, Eagle, and they can't be bothered to build a rod that can be used with a pressed wrist pin.
I had long ago realized that the piston selection for 383s was bad, but didn't figure out until recently that the rod selection is even worse.
Same here.
I don't even want to sit down to figure out how much I have in my STOCK 383 build the block has gone thru 3 shops , the first 1 screwed up a bunch of things , the second one corrected all but 1 $$$ , the third fixed the one and assembled the shortblock , diamond custom which really turned out to be not so custom since the block has had .030 cut off it because of the first 2 shops , the only real change the the shelf diamond at this point is smaller valve reliefs 3cc instead of 5 , i did it as a compromise because once I get the pure stock bug out of my head I'm going to put on a ported set of heads and a bigger cam.
If you want to get a set of eagles you might want to sooner than later because I have a feeling they are going to go the way of the dodo, just like the rod 440source has discontinued long ago.
Might be better to use a 440 rod , and have a lighter custom made .
[Re: JohnRR]
#976695
04/27/11 10:38 PM
04/27/11 10:38 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
I'd agree with your feeling. Last time I checked the Eagle website, they don't even have the 6.358" rod listed.
I've got a set that I picked up last year. Just wasn't smart enough to realize that they wouldn't work with the SP 2315s. The 2315s are going back to Mancini for a credit on a set of semi-custom Diamonds.
Block is supposed to be decked tomorrow, so I can determine whatever pin height I need based on how much they need to cut to square it.
