Not Running Right on Long Trips and/or lower Elevations
#976144
04/18/11 11:48 PM
04/18/11 11:48 PM
Posts: 842 Urbana, MD
bordin34
Urbana, MD
So a couple weeks ago I drove my car down to Englishtown,NJ (50ft) from my home in Mahwah,NJ (350ft), about a 2 hour drive down the highway. When I went to race on the 1/4 mile at Englishtown, the car pulled normal in first then just died and sputtered in second. My 1/8 and 1/4 mile mph were the same. Also the car didn't run right for the rest of the night in any gear really. It ran as if somebody decided to play with the timing. On the way home, the further north I drove, higher elevation, the better the car ran. I wouldn't think that only a 300ft change in elevation could make the car run worse, but I was only running #65 jets in the primaries and #68 secondaries. The next day I changed the primaries to #69 and the car actually ran better and was more responsive. I thought I found part of my problem. Fast forward to this past weekend, I drove from my home to Atlantic City, about 2.5hrs on the highway and again the more South I drove the worse the car ran, to the point that if I really tried to accelerate at all the car misfired and stuttered the whole time. It would however run right at a cruise rpm with little load. If I had to accelerate I would need to drop down a gear to avoid the stuttering. After the car show was over, about 5hrs, I restarted the car and it ran just as poorly. On my ride home it seemed to run better the more north I went, but it still was stuttering a bit when I got home. To top it off I only got about 8-9 highway mpg the whole time, I usually get 15 highway mpg. Any ideas? The motor is a 73 400, with a '70 383 4-bbl intake, 670cfm Holley Street Avenger, no vacuum advance, a mild cam, 727, and 2.45 rear gear.
Re: Not Running Right on Long Trips and/or lower Elevations
[Re: bordin34]
#976145
04/18/11 11:52 PM
04/18/11 11:52 PM
RapidRobert
WAG's: plugs/wires/vac leak
[Re: bordin34]
#976148
04/19/11 10:54 AM
04/19/11 10:54 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Thanks, it is a 300ft change not 3000ft. I would like to think my ignition system is up to par. Everything is about 3000 miles old. I have an MSD Streetfire box, stock distributor, firecore wires, and NGK plugs. My only thought would be that when I replaced the distributor, it was hard to get the reluctor gap tight enough and can't be gapped to the proper gap without making the slot longer.
300ft is hardly an elevation change , you could do that going across town if you live in a hilly area.
Your problem is in the distributor, you shouldn't have to elongate the slot to get the proper gap .
[Re: bordin34]
#976150
04/19/11 02:48 PM
04/19/11 02:48 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
John is right, you should not have to alter the slot. Is your reluctor wore out? Also this measurement should be done with a brass feeler gauge otherwise you can damage the pickup coil. It may be that your pickup coil is on it's way out, I had the same symptoms when mine started to go and it got progressively worse until it quit.
