3 trans id ??? #976024
04/18/11 08:47 PM
04/18/11 08:47 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
need the following 3 trans id info
what year and engine combo ?
will the case interchange on allusing vb from last one ?
4058395 7129 9267
4058394 7119 8666
4348783 87506551
thank you !
Re: 3 trans id ??? [Re: calrobb2000] #976025
04/18/11 10:17 PM
04/18/11 10:17 PM
scratchnfotraction Offline
i look up them as...
1) 4058395
dodge truck 82-83
8-318 & 8-360 A727
D-150,D-250 & D-350 4x2
long extension
dodge truck 82-83
8-318 & 8-360 A-727
B-150,B-250 & B-350
ramcharger 82
trailduster82
2)4058394
dodge truck 81 8-318 & 8-360
D-150 & D-250
long extesion & lock up converter
dodge truck 82-83 8-318 & 8-360 A727
D-150,D-250 & D-350
long extension and lock up converter
3)4348783... not found,sure this is not 4348703? if so it list as..
diplomat 86 8-318 A904
gran fury 86 8-318 A904
5th ave 86 8-318 A904
hope that helps
Re: 3 trans id ??? [Re: scratchnfotraction] #976026
04/18/11 11:24 PM
04/18/11 11:24 PM
s. e. pa.
s. e. pa.
hi
thanks scratchin
no 3 is correct numbers , may be from 86 4 wheel truck but not positive ???
Re: 3 trans id ??? [Re: calrobb2000] #976027
04/19/11 07:52 AM
04/19/11 07:52 AM
I dont have that # in my info,sorry
4x4 would have a xfer adaptor on back of the case,cant miss the look of that
or it would be a shorty with bolt on yoke like in a crew cab or divorced xfer truck
