Re: What will it dyno! (engine dyno)
[Re: moparniac]
#974173
04/16/11 12:54 PM
04/16/11 12:54 PM
Posts: 903 Saskatchewan, Canada
cudabin
The cam specs will dictate how much and where, as well as how long it will hold after peak... Not enough detail for a real good guess, but i will play anyways! 837hp@ 6,800 rpm. Good luck ![](/ubbthreads/images/graemlins/thumbs.gif) Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: moparniac]
#974174
04/16/11 01:13 PM
04/16/11 01:13 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
Prolly about a monthish out from being done with my new bullet but wanted to see what your guesss are! First time ever to go to dyno also so any tips to be prepared would be helpful also
Special thanks goes out to Competition Wedge on here for hooking me up with some new bottom end parts! Also like my new Superformance gasket set also thanks to the guys who sent some helpful pm's ![](/ubbthreads/images/graemlins/thumbs.gif)
New Combo(pump gas baby ) 574CI World Aluminum Block 4.500*4.505 7.100 rod Indy 440-1 CNC 345's from Best Machine 2.25*1.81 ferreas backcut k motion k 1000H springs Indy dominator pattern intake milled and ported Good size custom comp 3/4 roller 112 wide and in at 108 from 112 ![](/ubbthreads/images/graemlins/biggrin.gif) TD rockers 1.65 Milodon GD ATI balancer Melling HV pump windage tray milodon static pickup CVR 55GPM electric waterpump 11.89 to 1 compression
Dynamic compression ratio is 8.84:1 Dynamic cranking pressure is 180.84 PSI. (calculated via wallace @ 0 altitude)
.051 quench Diamond pistons cut deeper and rolled edges Total seal rings steel top .028 napier 2nd .032 Pro Systems SV1 (1212CFM) TTI/Proparts 2-2 1/8th ceramic coated headers MSD goods
tried to be detailed.... prolly forgot something though!
I'll take a SWAG, on your dyno 900+ HP at or above 6300 RPM with 810 Ft. Lbs , on my dyno 845 HP with 775 Ft. lbs at 7000 RPM and on Drams dyno 510 HP at 5900 RPM with 550 ft. lbs on FL pump gas All kidding aside that motor should make 900 + HP on pump gas, be very careful on the ignition timing, spark plug heat range and jetting, richer is better to start with along with a cold plug ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#974175
04/16/11 01:38 PM
04/16/11 01:38 PM
Quicktree
on pump gas with a 3/4 cam I doubt it.
[Re: emarine01]
#974176
04/16/11 04:35 PM
04/16/11 04:35 PM
Posts: 3,695 nc
emarine01
nc
A quick question on quench..... Small blocks run .040 max.... is it the same for larger cube engines?
....... .... is .051 a functional quench for a big block ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: moparniac]
#974180
04/17/11 07:57 AM
04/17/11 07:57 AM
quick77rt
Parts Problem
Parts Problem
Yep a pretty piston, if ya got the other 7 to go with it. I gotta ask, is this the first aftermarket piston you have ever seen??? What do you expect it to look like, one of your old ones? What will it dyno?? Without cam specs this sounds like a chebbie post, with the secret 3/4 cam crap. ![](/ubbthreads/images/graemlins/eyes.gif) Everytime Ive heard some chevy redneck galk about there 3/4 cam, yep they run 9-s...in the 1/8. But all BS aside good luck with the new motor, alot of time, money and hard work and money ![](/ubbthreads/images/graemlins/thumbs.gif) Did I say money ![](/ubbthreads/images/graemlins/apimp.gif) Dyno it up here, it might make 650hp....take 25% off at a REAL 8400FT. Quote:
sure is a pretty diamond piston though! ![](/ubbthreads/images/graemlins/scope.gif)
[Re: moparniac]
#974182
04/17/11 08:15 AM
04/17/11 08:15 AM
Posts: 30 Australia
Charger VJ RB
Australia
What will it dyno! (engine dyno) Not much ![](/ubbthreads/images/graemlins/laugh2.gif) No seriously 500 hp at idle ![](/ubbthreads/images/graemlins/laugh2.gif) Ok Ok it will turn 861hp on the dot. ![](/ubbthreads/images/graemlins/thumbs.gif)
RB XE274H Q-850
[Re: emarine01]
#974186
04/17/11 10:00 AM
04/17/11 10:00 AM
Posts: 3,695 nc
emarine01
nc
[Re: emarine01]
#974187
04/17/11 10:20 AM
04/17/11 10:20 AM
Posts: 6,295 U.S.
moparniac
U.S.
I'd just start another thread on that and I'd bet some of the top experts will comment on that! Just a hunch but they may tell you .040 is tight for BB and .055 may be the limit... Ask them though!
Mopar Performance
[Re: moparniac]
#974189
04/17/11 11:05 AM
04/17/11 11:05 AM
Posts: 3,695 nc
emarine01
nc
@ this point I have no intention of building a big block so I really don't have to know the real answer, you didn't say on piston wall clearance so if they are loose and rock a lot than .051 may be fine I thought it was a simple question cause this is for the most part a big block thread ....
