Page 2 of 3 1 2 3
Re: What will it dyno! (engine dyno) [Re: emarine01] #974170
04/16/11 10:19 AM
04/16/11 10:19 AM
U.S.
moparniac Offline OP
U.S.
Is the 73 @ 112 or 108?
that was at 112 and thats all your getting outta me
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: emarine01] #974171
04/16/11 10:21 AM
04/16/11 10:21 AM
U.S.
U.S.
sure is a pretty diamond piston though!
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974172
04/16/11 12:52 PM
04/16/11 12:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you should of let Todd build it, maybe it will last longer than your last one
Re: What will it dyno! (engine dyno) [Re: moparniac] #974173
04/16/11 12:54 PM
04/16/11 12:54 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
The cam specs will dictate how much and where, as well as how long it will hold after peak...
Not enough detail for a real good guess, but i will play anyways!
837hp@ 6,800 rpm.
Good luck
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: What will it dyno! (engine dyno) [Re: moparniac] #974174
04/16/11 01:13 PM
04/16/11 01:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
Prolly about a monthish out from being done with my new bullet but wanted to see what your guesss are! First time ever to go to dyno also so any tips to be prepared would be helpful also
Special thanks goes out to Competition Wedge on here for hooking me up with some new bottom end parts! Also like my new Superformance gasket set also thanks to the guys who sent some helpful pm's
New Combo(pump gas baby )
574CI World Aluminum Block
4.500*4.505
7.100 rod
Indy 440-1 CNC 345's from Best Machine
2.25*1.81 ferreas backcut
k motion k 1000H springs
Indy dominator pattern intake milled and ported
Good size custom comp 3/4 roller 112 wide and in at 108 from 112
TD rockers 1.65
Milodon GD
ATI balancer
Melling HV pump
windage tray
milodon static pickup
CVR 55GPM electric waterpump
11.89 to 1 compression
Dynamic compression ratio is 8.84:1
Dynamic cranking pressure is 180.84 PSI.
(calculated via wallace @ 0 altitude)
.051 quench
Diamond pistons cut deeper and rolled edges
Total seal rings
steel top .028
napier 2nd .032
Pro Systems SV1 (1212CFM)
TTI/Proparts 2-2 1/8th ceramic coated headers
MSD goods
tried to be detailed.... prolly forgot something though!
I'll take a SWAG, on your dyno 900+ HP at or above 6300 RPM with 810 Ft. Lbs , on my dyno 845 HP with 775 Ft. lbs at 7000 RPM and on Drams dyno 510 HP at 5900 RPM with 550 ft. lbs on FL pump gas All kidding aside that motor should make 900 + HP on pump gas, be very careful on the ignition timing, spark plug heat range and jetting, richer is better to start with along with a cold plug
Re: What will it dyno! (engine dyno) [Re: Cab_Burge] #974175
04/16/11 01:38 PM
04/16/11 01:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
4.500*4.505
7.100 rod
TD rockers 1.65
Milodon GD
ATI balancer
Melling HV pump
windage tray
.051 quench
Total seal rings
steel top .028
napier 2nd .032
MSD goods
on pump gas with a 3/4 cam I doubt it.
Re: What will it dyno! (engine dyno) [Re: emarine01] #974176
04/16/11 04:35 PM
04/16/11 04:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A quick question on quench..... Small blocks run .040 max.... is it the same for larger cube engines?
....... .... is .051 a functional quench for a big block
Re: What will it dyno! (engine dyno) [Re: Quicktree] #974177
04/16/11 05:31 PM
04/16/11 05:31 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
4.500*4.505
7.100 rod
TD rockers 1.65
Milodon GD
ATI balancer
Melling HV pump
windage tray
.051 quench
Total seal rings
steel top .028
napier 2nd .032
MSD goods
i agree. i did not make that much with 14.1 cr with more cylinder head and a bigger cam.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: What will it dyno! (engine dyno) [Re: Old School] #974178
04/17/11 02:56 AM
04/17/11 02:56 AM
U.S.
U.S.
Id say 900 is high myself lolz... thx for the guess though cab! Id be very happy with 800hp/725tq
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974179
04/17/11 07:23 AM
04/17/11 07:23 AM
ontario, canada
shag766 Offline
shag766  Offline
ontario, canada
first i am not a motor head but i think sledge is real close on his 800 and 725. i just had a dart engine built at westech performance group with close to your specs and it came 823 and 738 on pump gas. it is to be a feature article in engine masters. may edition i hope. they were real concerned with compression and stopped at 10.5 to 1 for pump gas.
good luck sledge.
Re: What will it dyno! (engine dyno) [Re: moparniac] #974180
04/17/11 07:57 AM
04/17/11 07:57 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Yep a pretty piston, if ya got the other 7 to go with it. I gotta ask, is this the first aftermarket piston you have ever seen??? What do you expect it to look like, one of your old ones?
What will it dyno?? Without cam specs this sounds like a chebbie post, with the secret 3/4 cam crap. Everytime Ive heard some chevy redneck galk about there 3/4 cam, yep they run 9-s...in the 1/8.
But all BS aside good luck with the new motor, alot of time, money and hard work and money Did I say money
Dyno it up here, it might make 650hp....take 25% off at a REAL 8400FT.
Re: What will it dyno! (engine dyno) [Re: quick77rt ] #974181
04/17/11 08:05 AM
04/17/11 08:05 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
11.89compression and pump gas? better make sure its good gas.anyway with hp gotta make 850+and tq like monster
Re: What will it dyno! (engine dyno) [Re: moparniac] #974182
04/17/11 08:15 AM
04/17/11 08:15 AM
Australia
Charger VJ RB Offline
Australia
What will it dyno! (engine dyno) Not much
No seriously 500 hp at idle
Ok Ok it will turn 861hp on the dot.
RB XE274H Q-850
Re: What will it dyno! (engine dyno) [Re: fishy340] #974183
04/17/11 09:12 AM
04/17/11 09:12 AM
U.S.
U.S.
Straight outta the pump 93 baby!!! cause thats the way I roll (cam should help )
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: shag766] #974184
04/17/11 09:13 AM
04/17/11 09:13 AM
U.S.
U.S.
good luck sledge.
thx! whenever the mag article come out let us know
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974185
04/17/11 09:19 AM
04/17/11 09:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well without knowing the cam I would think you can
make 775-800 which is only 1.35 - 1.4 times the CI
Re: What will it dyno! (engine dyno) [Re: emarine01] #974186
04/17/11 10:00 AM
04/17/11 10:00 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Re: What will it dyno! (engine dyno) [Re: emarine01] #974187
04/17/11 10:20 AM
04/17/11 10:20 AM
U.S.
U.S.
I'd just start another thread on that and I'd bet some of the top experts will comment on that! Just a hunch but they may tell you .040 is tight for BB and .055 may be the limit... Ask them though!
Mopar Performance
Re: What will it dyno! (engine dyno) [Re: moparniac] #974188
04/17/11 10:36 AM
04/17/11 10:36 AM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
Ill guestimate 670h.p about 25 percent less than if it had a whole cam
Re: What will it dyno! (engine dyno) [Re: moparniac] #974189
04/17/11 11:05 AM
04/17/11 11:05 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
@ this point I have no intention of building a big block so I really don't have to know the real answer, you didn't say on piston wall clearance so if they are loose and rock a lot than .051 may be fine I thought it was a simple question cause this is for the most part a big block thread ....
Page 2 of 3 1 2 3
