Re: lleaking TTI's
[Re: dusterbd13]
#973223
04/15/11 07:40 PM
04/15/11 07:40 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Get up early on a chilly morning and fire it up. Look around quickly while the engine is still cold, you should be able to see the condensation vapor leaking out where ever the leak is.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
Re: lleaking TTI's
[Re: JonC]
#973226
04/15/11 10:43 PM
04/15/11 10:43 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
snag a used stethoscope from ebay. remove the chest piece from the end, and put a small piece of metal tube on it. (to keep from melting the rubber) move around all flanges and welds, with the tip. you'll know the leak, when you find it. the post up top, is the same thing. a rubber tube/hose held to your ear, will amplify the leak, as you move it around the engine. it will be obvious when you find it. sort of like using a big screwdriver to listen for knocks. just making do, with what you have.
Re: lleaking TTI's
[Re: dusterbd13]
#973228
04/15/11 11:39 PM
04/15/11 11:39 PM
Challenger 1
Cincinnati, Ohio
ive actually got a stethascope, just never tried using it to find exhaust leaks. if the rubber hose is the same thing, then ill just break out my stethascope sunday ewhen im down in the shop.
Exact same thing Doc, for us poor mechanics, I use a simple piece of 5/16"ID hose or tubing. It can be much longer than 3 feet and bigger diameter too. A small diameter tubing will transfer distint sounds when held real close to the tube. When you find the leak is is very loud in the tube and in your ear. Works the best for finding exhaust leaks. Try it your see. You don't even need the fancy ear peices and one ear is plenty.
Don't pour stuff down your carb or try looking under your car while it's running. That's not smart or safe.
You can tape the end of the tubing to a stiff wire and stick that wire anywhere you want from above, even between the four pipes where they join the collector. It works great.
Re: leaking TTI's
[Re: Challenger 1]
#973229
04/15/11 11:45 PM
04/15/11 11:45 PM
Posts: 533 North Dakota
440abody
North Dakota
I had the same problem with my TTi's on my 440 after the first couple of start ups. Turned out to be the gaskets. Swapped them all out for Remflex's and the problem went away. Also make sure you re torque your bolts on the header after a couple of heat cycles as they will also loosen up.
73 Dart Swinger 440/727 8.75 w/3.55's 34 Ford 3w coupe with a soon to be 1958 392HEMI!
