Factory heads - How consistent are your CC #s??? #973190
04/14/11 06:53 PM
04/14/11 06:53 PM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
Just curious what others have seen for variation in combustion chamber volume measurements when CCing heads???
Just had a set of 906 heads freshened up at the machine shop and my combustion chamber volumes vary between about 82/83 and 86 CCs, IIRC.
Based on everything I hear about the lack of consistency in Mopar factory tolerances, I assume this is pretty normal??? What have you guys found?
Also, any general consensus on how close these numbers should be for a well built street motor?
Re: Factory heads - How consistent are your CC #s??? [Re: rss] #973191
04/14/11 07:11 PM
04/14/11 07:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Not the same heads but I recently did some 452's , 1 to 1.5 cc difference , but I did a bunch of machining to the open part of the chamber.
I just did some math and you are looking at .27/.36 difference in compression from the 82/83 to the 86, I used a .030 over 440 for the calculations. In a mild street motor that's probably not that big a deal.
Re: Factory heads - How consistent are your CC #s??? [Re: JohnRR] #973192
04/14/11 07:52 PM
04/14/11 07:52 PM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
That's what I was thinking. Based on the variability of deck heights across a typical non-square Mopar block, I would think this level of variability would be pretty common and not much of an issue, but my new machinist seems to think it will be a problem.
I guess that before I do anything else, I'll have to bust out the buret again and doublecheck my numbers.
