727 Fluid #972975
04/14/11 12:21 AM
04/14/11 12:21 AM
Pittsburgh,Pa
Dads70RTConv Offline OP
Pittsburgh,Pa
Ok in the last 6 months i inherited my dads 70 coronet .......the tranny is down some fluid what is a good fluid to use in a 727 nowadays??
Miss ya Dad 3-31-55 9-21-10 70 Coronet R/T Convertible
Re: 727 Fluid [Re: Dads70RTConv] #972976
04/14/11 12:31 AM
04/14/11 12:31 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I use ATF-4 but I've heard it doesn't matter, supposedly you can use Dexron if need be.
Re: 727 Fluid [Re: Dads70RTConv] #972977
04/14/11 09:11 AM
04/14/11 09:11 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
DROP the pan ... check the filter and see what is in the pan and REfill with some F-type ATF.
Re: 727 Fluid [Re: dOoC] #972978
04/14/11 04:44 PM
04/14/11 04:44 PM
These trannies aren't too picky, I might limit the amount of Ford ATF that I used. Less clutch slip upon engagement but thats a two edged sword with an older condition unknown transmission. Hate for the first firm shift to be the last one before rebuild.
