question on rear swap on my 69 Dart #972815
04/13/11 08:21 PM
04/13/11 08:21 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
I have a 69 Dodge Dart GT with a 7 1/4 rear and I am going to switch out rear to a 8 3/4 rear A-Body, but it has the small 4" bolt pattern what do I have to do to switch it out for a 4 1/2" bolt pattern and is it a easy swap
Re: question on rear swap on my 69 Dart [Re: 75dusted] #972816
04/13/11 09:06 PM
04/13/11 09:06 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If you don't have the 8 3/4 yet, look for one from a 65-67 B body. They will have the big bolt pattern and even though the axle will be wider, you may be buying new wheels anyway. I have a 66 Coronet axle in my 67 Dart. Standard 15x6 wheels clear fine. I have 235 60 tires too.
Your other options include buying NEW axles with new bearings. Prices vary, but they are usually over $250.
Re: question on rear swap on my 69 Dart [Re: Kern Dog] #972817
04/13/11 09:48 PM
04/13/11 09:48 PM
scratchnfotraction Offline
you have to have the drums and axle re-drilled from 4" to 4.5" wbp
or use an early B-body 8 3/4 housing
or like I did,set of moser A-body spec axles with the large brake offset,green bearings(or a stock bearing)
they will make the whole A-body 8 3/4 rear axle a 1/2" wider(1/4" each side)
I ran a 7" rim with a 4.5 backset with a 245/60/15 on my 68Dart fit was perfect in the fender wells
FYI,I took the same A-body 8 3/4 axle and bolted it in the 88 440 truck I built to run 12" wide rims and a 29x15x15 M/T..used the same 4.5 backset tucked them right in
A-body and trucks share the same 43" spring centers
and dont forget to put some lipstick on the 8 3/4 when it goes in the A-body
Re: question on rear swap on my 69 Dart [Re: 75dusted] #972818
04/13/11 10:50 PM
04/13/11 10:50 PM
As said go w the 65-67 B & deal w the wheel offset and the pad perch C to C diff or get a 1/2 Ton truck 8&3/4 & weld some new perches on the bottom side which'll let you set the pinion angle dead on w your cars' rake/springs. W you having a SBP 8&3/4 already you can redrill/tap the flange for 4&1/2" and use THREADED not press in studs (1/2-20). Moroso has them. Can have Moser in portland Indiana shorten a set of 1/2ton truck or C body or b or e (one of the two "b or e" I forget which) axles & use std 70's BBP 10" drum brakes from an 8&1/4 or 8&3/4 or 11" drum setup which'll require 15" wheels
Re: question on rear swap on my 69 Dart [Re: scratchnfotraction] #972819
04/13/11 10:50 PM
04/13/11 10:50 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
I want to have the springs moved inward with the relocation kit, so I can put 275/60-15 tires on the rear, so I was just wondering whats the best way to accomplish this
Re: question on rear swap on my 69 Dart [Re: 75dusted] #972820
04/13/11 11:08 PM
04/13/11 11:08 PM
As you know w that you'll be relocating the perches either way so it'd come down to modding the ends of your current SBP 8&3/4 for BBP or diff axles or grabbing a complete BBP 8&3/4 rear. Do you have your wheels picked out & know the backspace on them? EDIT W your SBP 8&3/4 did you get shock plates/ubolts/nuts w it as they're diff from the 7&1/4 ones
Re: question on rear swap on my 69 Dart [Re: RapidRobert] #972821
04/14/11 08:30 AM
04/14/11 08:30 AM
move the spring mounts into the frame rails/move perches on the axle
pop in a set of BBP axles with greens and your done
just spec the A-body axles with the large brake offset and the 4.5 BBP
use any brake set up off b-c-d-e-f-m-r body 8 1/4-9 1/4-8 3/4
then pic your rim with correct backset
IIRC you may have to mini tub it for that tire wheel combo
Re: question on rear swap on my 69 Dart [Re: RapidRobert] #972822
04/14/11 09:53 AM
04/14/11 09:53 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Not only have you given incorrect info about big blocks, now you are giving incorrect info on brake size/wheel combos and the axles that can be shortened.
First, 11" drums REQUIRE 15" wheels ??? That's funny hundreds of thousands of B bodies with 11" drums came standard with 14" wheels, in fact anything that didn't have a Hemi up to the beginning of the 70 model year ONLY came equipped 14" wheels.
Next, axles that can be shortened , there aren't any B or E body axles I have ever seen or seen written about in tech articles that can be shortened and resplined for use in an A body, only SOME C body axles and possibly older pickup axles might be able to usourced for this .
75dusted , do you already have an A body 8.75? Have you already swapped the front over to the big bolt pattern, there is a lot of ASSuMEing in this thread.
edited because of thin skins
Re: question on rear swap on my 69 Dart *DELETED* [Re: JohnRR] #972823
04/14/11 10:06 AM
04/14/11 10:06 AM
Post deleted by tboomer
Re: question on rear swap on my 69 Dart [Re: scratchnfotraction] #972824
04/14/11 10:12 AM
04/14/11 10:12 AM
Sorry scratchin , I wasn't referring to you or the grammar nazi as fruitloops .
Nice picture , right click save as ...
Re: question on rear swap on my 69 Dart [Re: JohnRR] #972825
04/14/11 11:13 AM
04/14/11 11:13 AM
For give my Ignorance then,thank you.
back on topic..
i have a set of c-body axle that can NOT be cut down to A-body specs,a set of 72 4x4 truck axles that CAN be cut down,but have the 5 on 5.5 wbp.
my 67 polara axles are 30" long and CAN be cut down,but I am told a 67 polara is a c-body.
but dont some of the B-bodys and E-bodys use a 30" axle?
C-bodys and trucks/vans are the best place to find axles that are not tapperd down and could be cut to A-body specs,IMHO the C-bodys are hit and miss
KG just poped a re-splined 8 1/4 axle couple days after doing it,IMHO the 299$ for a set of moser custom alloy axles are worth the $ to do it right the first time.
Doctor diff can set you up for whats needed and a fair price as well
