Re: help with tire choice
[Re: speedy383]
#972803
04/13/11 08:42 PM
04/13/11 08:42 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Hey, I think your doing Darn great Your MPH is inline with your ET. Your second half 27 MPH pickup is inline IMO you dont have a Bunch of ET to pick up with better 60 ft.s But there is still some ET on the table. Your right IMO, your 60,s should be closer to a 1.33 or 1.34. Hey, your not that far off from having a perfect inline run IMO with that 1.37 As far as tire choice, I like MTs myself. But others ET the same and better with the Phoenixs or Goodyears. Others the MT,s. My question would be with a 3000# combo do you really need such a big wide tire. I think at 3000# you could use less, but you absolutley dont want to jeaperdize hook in margiinal conditions.
[Re: racerx]
#972808
04/15/11 11:48 AM
04/15/11 11:48 AM
Posts: 414 No. cal., sacramento usa
speedy383
Well,its a446 rb,bulldog heads 338 in @.600,14.7/1. 690/670 roller,2/1/8 hedders,53%/47weight at 3050. 4.56 gear 5000 stall ,off transbrake,these runs were leave at 3700,shift at 6500. trap rpm is 6500 at 138.Rons injection on methanol.I am not lacking for power,i am spinning into second gear.Car actually transfers weight and initial move is very good but then losses traction.The same chassis went 1.32 with only 550 hp. Shocks are new double adj.The suspension works better at 4200 leave and more et at 6800 shift but i want to solve the launch issue first.
[Re: speedy383]
#972809
04/15/11 05:57 PM
04/15/11 05:57 PM
Posts: 4,068 Mo.
racerx
Mo.
Thaxx's 4 the info.I See that your heads flow better than mine with 338@600 I'm a set of the stock -1's with milled 4 more compression.Hopefully next year i can have them ported
[Re: speedy383]
#972811
04/15/11 10:30 PM
04/15/11 10:30 PM
Posts: 4,068 Mo.
racerx
Mo.
Actually ,i bought this engine from a buddy that quit racing.The heads were ported by Hughes their stage 3 i think. They claim 348 @>700 but i would guess more like 325 max. Still plenty of power for what i want to do.I talked to a Goodyear engineer and he suggested their d1823, 31.5 14.5 4a compound.Hope to run tomorrow.
Hughes does a pretty good job on there porting had a set of 906's done about oh..15-20 years ago(still have them)ran pretty good 4 what they were on (446) Good luck with your tire selection
[Re: speedy383]
#972812
04/17/11 09:17 PM
04/17/11 09:17 PM
Posts: 4,068 Mo.
racerx
Mo.
Speedy Any luck with the G/Y's This weekend?I'm thinking of going to a M/T 10.5 just wondering how the Good/years do.
[Re: speedy383]
#972814
04/18/11 09:31 PM
04/18/11 09:31 PM
Posts: 4,068 Mo.
racerx
Mo.
i made several test hits and fortunately a couple of well known chassis builders watched the car and helped with shock adj. and tire pressure.Went 1.37 ,1.36 and 1,35 60 ,9.74 best.My incrementals from 330 on are very good(330 to 660in 2.17and 660 to 1000 in 1.90 but i am .14 slow from 60 to 330.There consensus is get new tires with a softer compound and the converter is too tight.So i will order tires tomorrow and hit the national ope at sacramento in a couple of weeks.
Cool and Good luck
