Re: Exhaust coming out of breather at idle?!? [Re: SomeCarGuy] #972039
04/12/11 08:49 PM
04/12/11 08:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Leaky valves usually will not cause blow by into the crank case to get out the breather.
Re: Exhaust coming out of breather at idle?!? [Re: challenger70] #972040
04/12/11 09:55 PM
04/12/11 09:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Are you sure you got the exhaust hooked up right?
Re: Exhaust coming out of breather at idle?!? [Re: Challenger 1] #972041
04/12/11 10:12 PM
04/12/11 10:12 PM
Central TX
roe Offline
roe  Offline
Central TX
Just curious, and thinking out loud here because Im still learning, but if its a small amount of fumes, could it be from the fuel tank venting system. On a stock system the breather is hooked up to the air cleaner, so any fumes etc...would be pulled back into the engine and never noticed right? But if hes running one of the breathers that basically looks like a filter, then the fumes/exhaust is only being noticed because its not being sucked back into the air cleaner?
Just a thought
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Exhaust coming out of breather at idle?!? [Re: challenger70] #972042
04/12/11 10:13 PM
04/12/11 10:13 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
have you confirmed that the PCV is working properly by taking the valve out of the valve cover while it's running? It should have a very strong vacuum when placing your thumb over the open end of the valve.
Re: Exhaust coming out of breather at idle?!? [Re: GTXX] #972043
04/13/11 12:31 AM
04/13/11 12:31 AM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
no, I assume you mean leave the hose on the valve and put my thumb over the part that would normally be in the valve cover? I have not tried that but it's practically brand new(not guranteeing it works, I know) I will try that when I get a chance.
Re: Exhaust coming out of breather at idle?!? [Re: Challenger 1] #972044
04/13/11 12:33 AM
04/13/11 12:33 AM
Berwyn, IL
Berwyn, IL
I sure hope so
Re: Exhaust coming out of breather at idle?!? [Re: challenger70] #972045
04/13/11 07:39 AM
04/13/11 07:39 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what cam is in the motor? if it's got low vacuum at idle, as most performance cams do, then it might not be enough to suck open the PCV valve.
most of those valves are designed to be a "controlled vacuum leak" they have a spring in them that will close the valve under low vacuum conditions, i.e. WOT, so that you don't lean the motor out when you need it the most.
so, verify that the PCV is actually open at idle. Every engine has SOME blow-by on the rings. fact of life. if the PCV is closed at idle, then it has nowhere to go and it WILL vent out the breather on the other side.
you might not have any problem at all! (but my money is on rings! )
a good leakdown tester can be put together prety cheap. harbor freight has them for like, $30. total junk. you need 2 gauges that read on the same scale, and the harbor frieght ones do not.
simple solution. buy a HF unit, and 2 compression testers at the parts store. swap the 2 gauges over to the leakdown tester, and now you have one with 2 gauges that read the same scale.
then you can snag one off and put it back on the comp tester when you want to find your cranking PSI.
**Photobucket sucks**
Re: Exhaust coming out of breather at idle?!? [Re: 70Cuda383] #972046
04/13/11 12:01 PM
04/13/11 12:01 PM
Berwyn, IL
Berwyn, IL
it's a comp cams XE274H http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=708&sb=2 I am starting to suspect the headgasket, next steps I guess are to test the pvc valve and get a leakdown tester. Thanks for your help everyone!
