Re: 727 Trans Kick Down Linkage Question-71 RoadRunner 383
[Re: 69Stinger]
#971955
04/12/11 06:04 PM
04/12/11 06:04 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Do you have the correct Mopar throttle lever extension (Edelbrock #1481) on that Edelbrock?
[Re: 69Stinger]
#971956
04/12/11 06:11 PM
04/12/11 06:11 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
Are you running the Chrysler linkage adapter Edelbrock sells for these carbs? I have never had an issue using stock linkage with the adapter. There are different kick down rods between small and big block and even B to RB, the carb slide bracket I believe is the same length on the big block 4 bbl engines. Small block 2bbl cars do have a shorter one. Not sure on 4bbl setups.
EDIT: Beat me on the adapter John
[Re: T2R9]
#971957
04/12/11 07:47 PM
04/12/11 07:47 PM
Posts: 178 New England
69Stinger
New England
Yes, I have the adapter installed - I should have mentioned that. I looked at it again and something just ain't right. Here's a picture, maybe it will help. There's about 3/4" of space at the rear of the slide bracket behind the throttle stud - there should be no space there.
Thanks everyone.
[Re: 69Stinger]
#971958
04/12/11 07:51 PM
04/12/11 07:51 PM
John_Kunkel
Rio Linda, CA
Is there an adjustable swivel at the transmission end of the rod?
[Re: 69Stinger]
#971960
04/12/11 10:16 PM
04/12/11 10:16 PM
Posts: 3,344 Central TX
roe
Central TX
When I was getting help on here with setting up my kickdown linkage, lots of guys showed me how the just took 2 of those slotted bars and bolted them together to esentially make one long bar, so the the slot was properly sitting against the throttle pin at idle. Problem solved.
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: JohnRR]
#971963
04/13/11 12:04 PM
04/13/11 12:04 PM
roe
Central TX
If it can fit, a spacer under that carb should help. I would help performance, and also give you a better angle for your kickdown linkage. I have a 1/2" spacer on mine.
[Re: roe]
#971964
04/13/11 12:17 PM
04/13/11 12:17 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
I was thinking the same thing.
OP what intake is that and does the car have an air grabber hood ?
[Re: 69Stinger]
#971970
04/13/11 11:27 PM
04/13/11 11:27 PM
69Stinger
New England
[Re: bee71mopar]
#971973
04/14/11 03:36 PM
04/14/11 03:36 PM
69Stinger
New England
It's not late - I'm still scratching my head on this! Based on the responses I've received above, we agree that the downward angle of the slide bar linkage is not right. Bee71Mopar inferred that 383 and 440 brackets are different, do you mean the height at which the throttle cable mounts is the difference? If so, then I would think that because the stroke/deck height on an RB motor is higher than a B motor, than the 383 bracket would be higher to compensate for the shorter stroke/deck height. If that's the case, then I probably do have the 383 bracket which is pushing the linkage up too high. I should then get a shorter 440 bracket??????? I want to say again that the kick down linkage,including adjustment and angle was perfect with the Holley carb and I only now have issues because of switching to the Edelbrock. The difference is with the carb - the throttle cable bracket on the carb must be set at a lower height than the Holley. Does anyone know this for sure? Thanks again everyone!
