Breakaway and 4 Wheel Brakes on Car Trailer - Needed? #971847
04/12/11 11:20 AM
04/12/11 11:20 AM
San Antonio, Tx
bulletpruf Offline OP
San Antonio, Tx
Fellas -
I have a flatbed car trailer, 2008 model, that about 23' from tail to hitch and is supposed to weigh 1,800 pounds (5,000+ pounds GVW when loaded). It's dual axle trailer with electric brakes on a single axle. I got pulled over in MD this past weekend and the cop said that he thought I needed breakaway brakes, which was news to me.
Trailer is used frequently for moving cars across several states - right now, I have cars in Ohio (resto), Virginia (current house), North Carolina (paint jail), and bringing one to Columbus, GA (new house) this weekend. Tow vehicle is 2003 Excursion with 7.3.
In doing a search, here is what I believe to be true - if your trailer is required to have brakes by state law, then it is required to have breakaway brakes. I've only been questioned about this once, but I don't want to thumb my nose at the law and invite more scrutiny.
Anyone have thoughts on the above? Any ideas on how much it costs to have breakaway brakes installed? I'm a good mechanic, but might let a pro handle this one.
On a related note, should I go to 4 wheel brakes? Any ideas on how much $ I would spend here?
Here's something I copied from a horse website:
"Thirty one states require brakes on at least one axle (2-wheel brakes) on trailers over 3000 lbs. GVW and 11 states require brakes
on both axles (4-wheel brakes) on trailers over 3000 lbs. GVW. In addition, 3 of those states that require brakes on trailers over 3000 lbs., require 4 wheel brakes on trailers over 4,000 lbs. (No matter how light your trailer is, when it is loaded with horses it will weigh 3000 lbs. or more!) The remaining states that do not require brakes per se have regulations that require the ability to stop the combination without sway from a specified speed over a specified distance."
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: bulletpruf] #971848
04/12/11 11:27 AM
04/12/11 11:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Should be easy to add on your trailer with electric brakes , a switch with a pull cord , a small battery and wire it into the brake wire . That's what it looks like on my trailer anyway ...
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: bulletpruf] #971849
04/12/11 11:27 AM
04/12/11 11:27 AM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
Electric Breakaway brakes only consist of a switch with a cable going to the tow vehicle and a battery box with a battery in wired into the brake system to apply battery power to the brakes if the cable pulls the switch.
Like here
Trailer brake setup
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: JohnRR] #971850
04/12/11 11:37 AM
04/12/11 11:37 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: bulletpruf] #971851
04/12/11 02:15 PM
04/12/11 02:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW The stuff is so cheap I see no reason not to have it... I use my local trailer parts supplier but just to give an idea how cheap this stuff is.....
Brake assemblies
http://cgi.ebay.com/ebaymotors/2-DEXTER-...ors_RV_Trailer_
Break away kit
http://cgi.ebay.com/ebaymotors/Trailer-E...otors_RV_Traile
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: 1_WILD_RT] #971852
04/12/11 02:27 PM
04/12/11 02:27 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
I upgraded my 18' open trailer from 2 to 4 wheel brakes and it made a HUGE difference in stopping power. Even if you have a trailer shop do it for you, it's cheap. Every once in a while, you'll get in a situation where you REALLY need to get stopped safely. You'll be glad you made the upgrade.
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: dOOc] #971853
04/12/11 02:29 PM
04/12/11 02:29 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
Hi Ted !
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: bulletpruf] #971854
04/12/11 02:37 PM
04/12/11 02:37 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
In NY it's mandatory now that all wheels have brakes..even 1 car trailers. Brake box is easy install and a good thing. I like the 4 wheel braking system
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Needed? [Re: terzmo] #971855
04/12/11 02:46 PM
04/12/11 02:46 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
So it is uNlegal to tow through NY with a single axle braking system on an open double-axle trailer ?
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Neede [Re: dOOc] #971856
04/12/11 04:26 PM
04/12/11 04:26 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
just rember unless you have it wired differnt...... on ele. brakes once it departs from the tow rig it now has no source of power to apply the brakes i have the master cyl kind on my trailer and i love it over the ele brakes
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Neede [Re: toplescuda] #971857
04/12/11 04:29 PM
04/12/11 04:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
"departs"?
Re: Breakaway and 4 Wheel Brakes on Car Trailer - Neede [Re: Challenger 1] #971858
04/12/11 04:48 PM
04/12/11 04:48 PM
San Antonio, Tx
San Antonio, Tx
Fellas -
Many thanks for all the input. There's a pretty good trailer shop nearby; I'll check with them to see what they can do it for.
Scott
