2 fuel pumps question
#971488
04/11/11 09:01 PM
04/11/11 09:01 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
on my cuda project. i'm running a fuel cell, since it has 2 outputs, i was thinking about putting 2 jegs pumps (for sale in race section is what got me thinking) on the car insted of just 1 mallory 140 like i have on the challenger which has always seemed like plenty.
with 2 pumps feeding one line, does that really increase pressure or create any other kind of problems? i'm running 1/2 aluminum line to the front of the car.
opinions?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: 2 fuel pumps question
[Re: sixpackgut]
#971489
04/11/11 09:09 PM
04/11/11 09:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
opinions?
I run 2 Holley black 150s... line out of the tank (one from each fitting to each pump then a Y going forward... a regulator up front with return.... you gain volume... if both pumps are equal then the pressure is equal but gain in volume/flow
[Re: sixpackgut]
#971492
04/12/11 06:55 PM
04/12/11 06:55 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
The base standard set up has always been two elec pumps (Holley blue pumps or equivalent) into one 1/2 line Two pumps do not increase pressure (as previously stated) but MAINTAIN volume. A typical race pump can create enough volume with the car at rest and at steady speed to supply the demands of the engine, but upon acceleration the volume drops dramatically do to physics (a body at rest tends to stay at rest) so the fuel in the lines gets harder to push (because it wants to "stay at rest") upon launch and if your car has any type of 60' time and acceleration, there isn't enough fuel in the bowls to support the "Lag" in fuel volume. Also one pump works at a given duty cycle (work over time)but two will cut that duty cycle in half, (half the work over same amount of time) and increase pump life greater than the cost of a new pump. (especially if you factor in the probability that it will fail just as you are about to line up for the finals!)As work demand goes up life goes down, it is not linier but exponential, meaning that if a devise is working at 90% duty cycle lives for 50 hrs, it will live much longer than 100hrs at 45% duty cycle(this is a fictious example but typical of most mechanical devices) Anyway all this goes out the window with the advent of the 250, 400, and larger race pumps that are available today, except for the duty cycle rule...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: sixpackgut]
#971494
04/12/11 08:06 PM
04/12/11 08:06 PM
Posts: 5,618 long island NY
Ari440
long island NY
fuelcell two #10 lines
going two inline fuel filters
going in two holley blue pumps
going into a Y block
#10 going to the front
to a four port magnafuel regulater
two #8 going to a
1050
1.39 9.85 - 137 mph
