Re: 2011 Challenger burns on assembly line
[Re: amxautox]
#970865
04/10/11 10:19 PM
04/10/11 10:19 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
It is pretty crispy. Apparently some attached paperwork as it rolls down the line was too close to a heat lamp. No broadcast sheet for this one now maybe??
[Re: anlauto]
#970868
04/10/11 11:07 PM
04/10/11 11:07 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
If I remember the correct term, the engineers at Chrysler call that a "Thermal Event" (fire). I do know that when I was on the 09 Ram launch team I wrote up a issue for a possible "Thermal Event" on the V-6 trucks for the fuel line connection at the fuel rail for being directly over a coil pack. If the o-ring was damaged on the installation or the connection was improperly done. If the connection ever leaked it would be a bad idea for it to be leaking directly onto a coil pack. One leak, one spark and I'd seen way too many fuel line connections not done or the connection o-ring damaged at the tank causing gas to be sprayed all over the top of the gas tank on the trucks. They said it wouldn't be an issue. The one in the pic looks like an SRT (SRT wheels).
[Re: mccannix]
#970870
04/11/11 11:02 AM
04/11/11 11:02 AM
Posts: 12,066 (Central) PA
Runner2go
(Central) PA
Wouldn't Deep Water Blue in 2011 make that an Inaugural Edition 392... Hmmm... I wonder if that was a US or Canadian car I guess they are going to have to change those dash plaques to either #xxxx of 1099 US, or #xxx of 391 CA
1966 383, 4-sp Charger 38yrs 1970 440+6, 4-sp Road Runner 36yrs 1974 360, auto Challenger 25yrs,in Family 41yrs 2003 Ram 2500 QCLB 4x4 Cummins HO 2010 5.7L R/T 6sp Challenger - Mopar10 2018 392 Daytona Charger
[Re: TX9H6E4CUDA]
#970879
04/11/11 04:04 PM
04/11/11 04:04 PM
Posts: 1,402 Littleton Colo
Geezer
Littleton Colo
Ahhhhh I don't know about the story of paperwork...........(no offense to the op) I have been looking at the insurance auctions for a challenger repairable and there are always a couple in the auction that are burnt and look like the car pictured. They are burned exactly the same way. Maybe there is a issue?
Fiat management likes to burn 1 or 2 cars per shift to increase production numbers but not increase cars in the sales bank.
[Re: Geezer]
#970880
04/11/11 04:32 PM
04/11/11 04:32 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
Are we sure this burned on an assembly line? What is the process in assembling these cars. It looks like it was gassed up and started before the front end parts were assembled. Is that normal procedure? How could the car burn for so long on an assembly line,don't they have fire extinguishers?
[Re: west]
#970882
04/11/11 04:51 PM
04/11/11 04:51 PM
Runner2go
(Central) PA
Maybe because the stoners where too busy using dip sticks to roast Marshmallows
