SB Moroso Waterpump wiring #969815
04/09/11 11:59 AM
04/09/11 11:59 AM
ont,canada
mopartuner Offline OP
ont,canada
Looking soe safe and smart ways to wire my waterpump.The car is a 65 cuda w/stock type harness and the battery is in the trunk.Not sure what amp the alternator is,maybe somebody can tell me how to check it with a meter.
Re: SB Moroso Waterpump wiring [Re: mopartuner] #969816
04/09/11 12:39 PM
04/09/11 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will assume you have a electric fan also... so I
would hook them up to 2 separate switches so you can
run them each on their own... wire them both with a
relay each so the switch is just to trigger the relay...
as to the alt and its output, you need a amp gauge
to show the max of the alt when you full field it
(most VOM cant handle the amps)
Re: SB Moroso Waterpump wiring [Re: MR_P_BODY] #969817
04/09/11 01:09 PM
04/09/11 01:09 PM
ont,canada
ont,canada
Yes Mr.P I have twin 12" Flexalite slimline fans on this thing and still have problems cooling it down.So I have 2 fans,fuel pump,waterpump,Crane digital 6 ignition box,lights ect.How many amp alt will I need?Will the stock harness be ok?
Re: SB Moroso Waterpump wiring [Re: mopartuner] #969818
04/09/11 01:18 PM
04/09/11 01:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The stock harness wont take the added amps... you
need to run a separate wire from the alt to the
battery(you can run a relay on the alt wire if you
want to have it shut it off so it isnt hot all the time)
Add up all the amps that everything will draw and
add 15% to it and thats what you need for a alt
If you put the relays near the item/draw you wont
get the line drop then you run a small wire to the
relay from the switch
Re: SB Moroso Waterpump wiring [Re: MR_P_BODY] #969819
04/09/11 01:46 PM
04/09/11 01:46 PM
ont,canada
ont,canada
This car has a dual field alt on it and I think that the field wires run to the voltage regulator on the firewall so there is 2 alt wires.I am not the best on this electrical stuff can you explain a little more?Thanks P.
Re: SB Moroso Waterpump wiring [Re: mopartuner] #969820
04/09/11 03:09 PM
04/09/11 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You need to ground one of the field wires... alot
of times I'll put a wire in the regulator connector
(out board pin) and plug the connector back on then
ground the wire... that will full field the alt
