Offenhauser Intake #969774
04/09/11 10:23 AM
04/09/11 10:23 AM
Anonymous OP
Anonymous OP
A coworker has an offenhauser 360 single carb intake manifold that will fit my 440. No carb comes with it. Are these intakes any good? What are the characteristics it has. Will my old AFB work with it? I could probably get it for $75 or so.
Re: Offenhauser Intake #969775
04/09/11 10:33 AM
04/09/11 10:33 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
REALLY old-school stuff .... save yurr money, skip this one, add a couple of bucks to the purchase and get a Street Dominator.
Re: Offenhauser Intake [Re: dOc !] #969776
04/09/11 10:53 AM
04/09/11 10:53 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I kind of agree with Doc on this one. Without seeing which one (there are a few choices available), it's hard to give good advise.
If you want it for the look, the nostalgia, go for it.
I owned and drove two different Offy intakes that were available, way back then. The Offy dual port that required a Thermoquad was very torquey off the line and had good throttle response, but at the track the Holley SD and Holley carb was about a second better for me.
The other Offy that was turle like and had a divider down the middle only (essentially making it two single planes divided down the middle), worked well on a car I bought, but I never track tested it.
I was always able to sell those Offy intakes for a good dollar to really old shool guys who just loved them. The Dual Port was sold for $400 25 years ago, here in Canada.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Offenhauser Intake #969777
04/09/11 11:07 AM
04/09/11 11:07 AM
If it's a dual plane and a DP fits your app (& I'm assuming it will as a dual plane fits most intended uses) then it'll b fine. As said not the perfect choice but money is tight and I'd approach him w (3) 20's in hand
Re: Offenhauser Intake [Re: RapidRobert] #969778
04/09/11 05:42 PM
04/09/11 05:42 PM
Anonymous OP
Anonymous OP
Thanks fellas, it has two seperate ports per intake runner and the primaries are seperated from the secondaries at the carb base. I'm not racing the car so I'm looking for appearance but not at the cost of everyday driving. He told me to make him an offer but he is a coworker and friend so I don't want to rob him. I see new equivalent ones go for around $400, I saw a used one on racing junk for $250. I will tell him he would probably be money ahead selling it online before I offer him the cash. The 440 is a first year from a New Yorker and has the factory cast 4 barrel intake on it. I have a mid 60's AFB which I have been using and which would save me a ton of cash if I could keep using it.
Re: Offenhauser Intake #969779
04/09/11 06:46 PM
04/09/11 06:46 PM
What prob are you having that's making you want to do some swapping
Re: Offenhauser Intake [Re: RapidRobert] #969780
04/09/11 07:18 PM
04/09/11 07:18 PM
Anonymous OP
Anonymous OP
No problems, the engine is needing a rebuild but it's sitting on a stand while I complete my never ending car resto. The AFB I have came from an old poly 4 barrel intake and I used it on the 440 just for a couple months before I commenced the car resto 4 years ago.
Re: Offenhauser Intake #969781
04/09/11 07:38 PM
04/09/11 07:38 PM
Central NC
gch Offline
gch  Offline
Central NC
That old afb is likely costing you as much hp as the flat intake.Too small for performance.Just fine for cruising.
Re: Offenhauser Intake #969782
04/09/11 08:49 PM
04/09/11 08:49 PM
racealittle Offline
racealittle  Offline
Sounds like an Offy Dual Port. The theory is a high velocity primary in half of the intake runner, and the full punch from the secondaries filling in the rest of the runner volume.
That is the intake I sold for $400. It was torquey as hell, but I just could not tune the TQ for more power than the 850 Holley dp. If my offy was a square bore intake, I would have likely kept it.
$400 was a lot of money back in those days. That intake cost over $500 CDN back in those days.
Re: Offenhauser Intake [Re: gch] #969783
04/09/11 08:49 PM
04/09/11 08:49 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I run the Offy and think it works well
Re: Offenhauser Intake #969784
04/09/11 09:33 PM
04/09/11 09:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've run a Offy in the past on a SB, mine ran real well.
I like em, old or not.
Re: Offenhauser Intake [Re: Challenger 1] #969785
04/09/11 10:03 PM
04/09/11 10:03 PM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
I have a small block Offy laying around. I wonder if it'd be worth putting it on my 360--currently just have an Edelbrock Performer on it.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
Re: Offenhauser Intake [Re: racealittle] #969786
04/09/11 10:15 PM
04/09/11 10:15 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
That Offy DP .... never ran one me-self but a bud did. Ran good except when he got into the secondaires. VERY restrictive inside that manifold. That intake must have been a horror show casting up...
4-5 huN beans ? ... DAMN
I am not familiar with the time-line .. but it was probably the same years that Eddy came out with the Streetmaster. That is a muchO bester intake than the Offy DP.
Re: Offenhauser Intake [Re: dOc !] #969787
04/10/11 11:04 AM
04/10/11 11:04 AM
Hey thanks Doc, I have a SM & was thinking I wanted to locate a dual port to better my mileage but now I'll forget about that & finding (smelled the gas) & fixing the pinhole leak in my line halfway back to the tank where the Adel clamp rubbed a hole in it has done wonders for my mileage. I dont get frustrated anymore (at least w car probs) but I for the life of me couldn't figure out the prob as the 318, nothing appeared to b out of whack (plugs/wires good, no apparent misfire, eddy 1406 somewhat lean, timing good) the only thing I could come up w was maybe a lean misfire & was wanting to get an Innovate LM-1 to dial it all in but even a misfire could not explain how fast the needle was dropping (and a locked gas cap has always been on there)
Re: Offenhauser Intake [Re: RapidRobert] #969788
04/10/11 11:27 AM
04/10/11 11:27 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RR ..... so you are talking about the SM for the A engine? I think I have one of those but all I have ever used are the ones for the B and RB.
There are some "dams" in those SM intakes that you have to wonder why they are there. ESPECIALLY the dams in A engine one. There has to be a reason for that because it would have been EZier for Eddy to build them without them.
I will see if I have a pic.
Re: Offenhauser Intake [Re: dOc !] #969789
04/10/11 11:33 AM
04/10/11 11:33 AM
Yes SB, yeah I got a SM on there now w an eddy 1406. It has miniscule ports/plenum but it IS a single plane & that part got me thinking if a swap would benefit
Re: Offenhauser Intake [Re: RapidRobert] #969790
04/10/11 11:38 AM
04/10/11 11:38 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
For a single plane TORQUE intake for a SB in a MPG project .. it has to be good piece.
If I ever built a SB mpg engine ...I think that I would stick-with an SP2P because it takes a TQ carb so EZ.
Re: Offenhauser Intake [Re: dOc !] #969791
04/10/11 11:44 AM
04/10/11 11:44 AM
Well I do have one of the "reverse" adapters to run a spreadbore carb on a square bore intake & if gas hits $5 I'll prob have Demonsizzler prep me a good TQ for the work vehicle
Re: Offenhauser Intake [Re: RapidRobert] #969792
04/10/11 11:51 AM
04/10/11 11:51 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
RR .... do you have a pic of that "throat" of the intake? I think that it is sooo restrictive.
Have you ever thought of prepping the carb yourself ? ... U R a sharp guy ...who could more-than-just-read a FSM.
It would take 10$ a gallon gas for a pay-back from an expense like that ..
Re: Offenhauser Intake [Re: dOc !] #969793
04/10/11 11:57 AM
04/10/11 11:57 AM
Doc I appreciate the vote of confidence. I didn't take a pic but I remem how small they were, you couldn't miss it. Are you saying I had better b sitting down when I ask David for a price . W all the warped bowls etc w them that got me thinking of contacting him
